[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-839-gc356da35f
Sun May 15 06:28:55 PDT 2022
the project "PostGIS".
       via  c356da35f061c2f3a1d55cdd2ead9b55efd4a415 (commit)
      from  a64f2dae908baf89aa1a45ccd4d25702f5a59845 (commit)
revisions in full, below.
commit c356da35f061c2f3a1d55cdd2ead9b55efd4a415
Author: Regina Obe <lr at pcorp.us>
Date:   Sun May 15 09:27:17 2022 -0400
    Change signature of AddToSearchPath, references #5150
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index ab5e654db..4d9b19538 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -18,7 +18,7 @@
 -- this is needed because there is no ALTER EXTENSION DROP FUNCTION/AGGREGATE command
 -- and we can't CREATE OR REPALCe functions whose signatures have changed and we can drop them if they are part of an extention
 -- So we use this to remove it from extension first before we drop
-CREATE OR REPLACE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
+CREATE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
   RETURNS boolean AS
 DECLARE
@@ -81,7 +81,7 @@ END;
 LANGUAGE plpgsql VOLATILE;
-CREATE OR REPLACE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
+CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
   RETURNS boolean AS
 DECLARE
@@ -101,7 +101,7 @@ END;
-CREATE OR REPLACE FUNCTION postgis_extension_AddToSearchPath(a_schema_name varchar)
+CREATE FUNCTION postgis_extension_AddToSearchPath(a_schema_name text)
 RETURNS text
 AS
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index b08048fd9..2fb1d1756 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -15,4 +15,5 @@
 -- and should be called at the end of the extension upgrade file
 DROP FUNCTION postgis_extension_remove_objects(text, text);
 DROP FUNCTION postgis_extension_drop_if_exists(text, text);
-DROP FUNCTION postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
Summary of changes:
 extensions/postgis_extension_helper.sql           | 6 +++---
 extensions/postgis_extension_helper_uninstall.sql | 3 ++-
 2 files changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
