[postgis-tickets] [PostGIS] #5152: ST_Split goes into infinite loop with empty geometries
PostGIS trac at osgeo.org
Tue May 17 13:24:34 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  reopened
  Priority:  blocker  |  Milestone:  PostGIS 2.5.7
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"e039130b3d3a9e905c7ffb8dab6976fed1330a7f/git"
 e039130b/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e039130b3d3a9e905c7ffb8dab6976fed1330a7f"
 Fix infinite loop in lwline_split_by_point_to
 References #5152 in 3.0 branch (3.0.6dev)
 Includes unit and regress test
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5152#comment:8>
