[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.5-10-gc14e9a059
Tue May 17 21:27:31 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  c14e9a059aca3ee39fdbfab88190da5172a81122 (commit)
       via  13bf5f18b8a06f49b76a06795e601dd0f8a18059 (commit)
       via  34d07134f7479b1a90bc195c7765e0425c234a86 (commit)
      from  2979ae7cca0e1960991276e9fb724bcbf369cc07 (commit)
revisions in full, below.
commit c14e9a059aca3ee39fdbfab88190da5172a81122
Author: Regina Obe <lr at pcorp.us>
Date:   Wed May 18 00:26:06 2022 -0400
    Return error on ST_SetPoint emtpy linestring.
    References #5151 for PostGIS 3.1.6
diff --git a/NEWS b/NEWS
index 10da6e890..1f54a4460 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ PostGIS 3.1.6dev
   - #5076, Avoid log storm installed with pgaudit enabled (Paul Ramsey)
   - #5100, Stop using pg_atoi, removed in PG 15 (Laurenz Albe)
   - #5115, Allow dropping topologies with pending constraints (Sandro Santilli)
+  - #5151, ST_SetPoint with empty geometries (Regina Obe)
 PostGIS 3.1.5
 2022/02/01
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 43b236bee..0a629912b 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2339,6 +2339,10 @@ Datum LWGEOM_setpoint_linestring(PG_FUNCTION_ARGS)
 		elog(ERROR, "First argument must be a LINESTRING");
 		PG_RETURN_NULL();
+	if ( line->points->npoints < 1 ) 	{
+		elog(ERROR, "Line has no points");
+		PG_RETURN_NULL();
 	if (which < 0)
 		/* Use backward indexing for negative values */
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index e07b50c7e..4e7e9933b 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1424,3 +1424,6 @@ WITH w AS (
 SELECT '#4770.c', ST_AsText(g), s FROM w;
+-- https://trac.osgeo.org/postgis/ticket/5151
+SELECT '#5151', ST_SetPoint(ST_GeomFromText('LINESTRING EMPTY',4326), 1, ST_GeomFromText('POINT(40 50)',4326)) As result;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 91b8e7cc6..9939a6b97 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -460,3 +460,4 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4770.b|POINT(1 1)|302
 #4770.c|POINT(0 0)|300
 #4770.c|MULTIPOINT(0 0,1 1)|602
+ERROR:  Line has no points
commit 13bf5f18b8a06f49b76a06795e601dd0f8a18059
Date:   Wed May 18 00:25:55 2022 -0400
    Have berrie stop on first error
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 88ccd964a..0573fd589 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -1,4 +1,5 @@
 #!/usr/bin/env bash
+set -e
 #bessie is a 32-bit Rasberry Pi managed by Bruce Rindahl
 ## BRANCH is passed in via jenkins which is set via gitea web hook
 #export BRANCH=618a67b1d6fc223dd5a4c0b02c824939f21dbd65
commit 34d07134f7479b1a90bc195c7765e0425c234a86
Date:   Wed May 18 00:18:53 2022 -0400
    Better testing of empties and window functions. Also logic to not skip nested ref entries
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index c8629eb8e..8aec3efc1 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -238,6 +238,21 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
 		</pgis:gset>
+		<pgis:gset ID="Empty Linestring" GeometryType="LINESTRING" createtable="false">
+		(SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Empty Point" GeometryType="POINT" createtable="false">
+		(SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Empty Polygon" GeometryType="POLYGON" createtable="false">
+		(SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom)
+		</pgis:gset>
+		<pgis:gset ID="Empty Geometry Collection" GeometryType="GEOMETRY" createtable="false">
+		 (SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom )
+		</pgis:gset>
@@ -481,7 +496,7 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 	</xsl:for-each>
 <!--End test on operators -->
 <!-- Start regular function checks excluding operators -->
-		<xsl:for-each select="sect1[not(contains(@id,'Operator'))]/refentry">
+		<xsl:for-each select="sect1[not(contains(@id,'Operator'))]//refentry">
 		<xsl:sort select="@id"/>
 			<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
@@ -511,11 +526,11 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 				  </xsl:choose>
 				</xsl:variable>
-				<!-- is a window function -->
+				<!-- is a window or aggregate function -->
 				<xsl:variable name='over_clause'>
 					 <xsl:choose>
-					 	<xsl:when test="paramdef/type[contains(text(),'winset')]">
-					 		<xsl:value-of select="'OVER()'"/>
+					 	<xsl:when test="paramdef/type[contains(text(),'set')]">
+					 		<xsl:value-of select="'OVER(ORDER BY random())'"/>
 					 	</xsl:when>
 					<xsl:otherwise>
 					  <xsl:value-of select="''"/>
Summary of changes:
 NEWS                               |  1 +
 ci/berrie/postgis_regress.sh       |  1 +
 doc/xsl/postgis_gardentest.sql.xsl | 23 +++++++++++++++++++----
 postgis/lwgeom_functions_basic.c   |  4 ++++
 regress/core/tickets.sql           |  3 +++
 regress/core/tickets_expected      |  1 +
 6 files changed, 29 insertions(+), 4 deletions(-)
hooks/post-receive
