[postgis-tickets] [PostGIS] #5155: extension helper functions some pg_catalog calls are not schema qualified
PostGIS trac at osgeo.org
Fri May 20 08:37:31 PDT 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 2.5.7
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"216aca6483a2fa65a33b488e103c1188c4ade878/git" 216aca6/git]:
 {{{#!CommitTicketReference repository="git"
 revision="216aca6483a2fa65a33b488e103c1188c4ade878"
 Fix some schema quals. References #5155 for PostGIS 3.3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5155#comment:2>
