[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-7-g6e0680a6e
Mon May 23 01:30:03 PDT 2022
the project "PostGIS".
       via  6e0680a6ec2ba5959d0566b655fa433173a40b83 (commit)
      from  c8abe00120a7669dc7cda5ff1bb4f1964dc3bb01 (commit)
revisions in full, below.
commit 6e0680a6ec2ba5959d0566b655fa433173a40b83
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon May 23 10:29:37 2022 +0200
    Add manpages for pgtopo_import and pgtopo_export
    Closes #5158
diff --git a/doc/Makefile.in b/doc/Makefile.in
index e02f5f459..0a0f29531 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -395,10 +395,14 @@ man-install: man/shp2pgsql.1 man/pgsql2shp.1
 	mkdir -p $(DESTDIR)$(PGSQL_MANDIR)/man1
 	$(INSTALL_DATA) man/pgsql2shp.1 $(DESTDIR)$(PGSQL_MANDIR)/man1/pgsql2shp.1
 	$(INSTALL_DATA) man/shp2pgsql.1 $(DESTDIR)$(PGSQL_MANDIR)/man1/shp2pgsql.1
+	$(INSTALL_DATA) man/pgtopo_export.1 $(DESTDIR)$(PGSQL_MANDIR)/man1/pgtopo_export.1
+	$(INSTALL_DATA) man/pgtopo_import.1 $(DESTDIR)$(PGSQL_MANDIR)/man1/pgtopo_import.1
 man-uninstall:
 	rm -f $(DESTDIR)$(PGSQL_MANDIR)/man1/shp2pgsql.1
 	rm -f $(DESTDIR)$(PGSQL_MANDIR)/man1/pgsql2shp.1
+	rm -f $(DESTDIR)$(PGSQL_MANDIR)/man1/pgtopo_export.1
+	rm -f $(DESTDIR)$(PGSQL_MANDIR)/man1/pgtopo_import.1
 docs-install: html/postgis.html html/style.css
 	mkdir -p $(DESTDIR)$(PGSQL_DOCDIR)/postgis/images
diff --git a/doc/man/pgtopo_export.1 b/doc/man/pgtopo_export.1
new file mode 100644
index 000000000..28c494545
--- /dev/null
+++ b/doc/man/pgtopo_export.1
@@ -0,0 +1,49 @@
+.TH "pgtopo_export" "1" "" "" "PostGIS"
+.SH "NAME"
+.LP
+pgtopo_export - postgis topology exporter
+.SH "SYNTAX"
+.LP
+pgtopo_export [\fIoptions\fR] \fIdatabase\fR \fItopology\fR
+.SH "DESCRIPTION"
+.LP
+The pgtopo_export script connects to the named database and exports
+data of the named topology and associated layers to a file with a
+custom format.
+.SH "USAGE"
+.LP
+The <database> is the name of the database to connect to.
+The <topology> is the name of the topology to read data from.
+.SH "OPTIONS"
+.LP
+The commandline options are:
+.TP
+\fB\-f\fR <\fIfilename\fR>
+Write the output to a particular filename instead of stadard output.
+.TP
+\fB\--skip-layers\fR
+Do not export layers, just topology primitives.
+\fB\-h\fR
+Display usage information.
+.SH "EXAMPLES"
+.LP
+An example session using the exporter to create an export file of a
+topology "city_data" from a database might look like this:
+# \fBpgtopo_export \-f city_data.pgtopo_export my_db city_data\fR
+.SH "AUTHORS"
+.LP
+Originally written by Sandro Santilli <strk at kbt.io>.
+.SH "SEE ALSO"
+.LP
+pgtopo_import(1)
+More information is available at http://postgis.net
diff --git a/doc/man/pgtopo_import.1 b/doc/man/pgtopo_import.1
index 000000000..8d4683c7a
--- /dev/null
+++ b/doc/man/pgtopo_import.1
@@ -0,0 +1,60 @@
+.TH "pgtopo_import" "1" "" "" "PostGIS"
+.SH "NAME"
+.LP
+pgtopo_import - postgis topology importer
+.SH "SYNTAX"
+.LP
+pgtopo_import [ --skip-layers | --only-layers ] [ -f <dumpfile> ] <toponame>
+pgtopo_import [\fIoptions\fR] \fItopology\fR
+.SH "DESCRIPTION"
+.LP
+The pgtopo_import data loader reads an export file written
+by pgtopo_export and outputs an SQL script reconstructing
+the topology therein contained.
+.SH "USAGE"
+.LP
+The <topology> is the name to give to the re-created topology, which
+can be different from the name of the topology the export was made
+from.
+By default the SQL script is written on standard output.
+.SH "OPTIONS"
+.LP
+These are the supported options
+(Note that \--skip-layers and \--only-layers are mutually exclusive.)
+.TP
+Do not include layers in the output SQL script. Just the topology
+schema.
+.TP
+\fB\--only-layers\fR
+Do not include the topology schema in the output SQL script. Just the
+layers.
+.TP
+Read the export file from the specified filename, rather than from
+standard input.
+\fB\-h\fR
+.SH "EXAMPLES"
+.LP
+An example session using the loader to create an SQL file and uploading it
+might look like this:
+# \fBpgtopo_import city_data < city_data.pgtopo_export | psql newdb\fR
+.SH "AUTHORS"
+.LP
+.SH "SEE ALSO"
+.LP
+pgtopo_export(1)
Summary of changes:
 doc/Makefile.in         |  4 ++++
 doc/man/pgtopo_export.1 | 49 ++++++++++++++++++++++++++++++++++++++++
 doc/man/pgtopo_import.1 | 60 +++++++++++++++++++++++++++++++++++++++++++++++++
 3 files changed, 113 insertions(+)
 create mode 100644 doc/man/pgtopo_export.1
 create mode 100644 doc/man/pgtopo_import.1
hooks/post-receive
