[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.1-20-gc43c35321
    git at osgeo.org
    git at osgeo.org
    Sat May 28 23:13:26 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  c43c353211bd6d27e53b254762ad67b093dc2361 (commit)
      from  568790ad1cbe48a71e96c0265f387c2b8ba35776 (commit)
revisions in full, below.
commit c43c353211bd6d27e53b254762ad67b093dc2361
Author: Regina Obe <lr at pcorp.us>
Date:   Sun May 29 02:10:12 2022 -0400
    More schema qualifications references #5155 for PostGIS 3.2.2
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index 4d9b19538..4677d81b6 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -28,48 +28,48 @@ DECLARE
 	var_class text := '';
 	var_is_aggregate boolean := false;
 	var_sql_list text := '';
-	var_pgsql_version integer := current_setting('server_version_num');
+	var_pgsql_version integer := pg_catalog.current_setting('server_version_num');
 BEGIN
-		var_class := CASE WHEN pg_catalog.lower(param_type) = 'function' OR pg_catalog.lower(param_type) = 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
-		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) = 'aggregate' THEN true ELSE false END;
+		var_class := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'function' OR pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
+		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN true ELSE false END;
-		IF var_pgsql_version < 110000 THEN
-			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3 || ' ' || COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes) || ')' ,typ.typname, cd.relname, op.oprname,
-					cs.typname || ' AS ' || ct.typname || ') ', opcname, opfname) || ';' AS remove_command
+		IF var_pgsql_version OPERATOR(pg_catalog.<) 110000 THEN
+			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' OPERATOR(pg_catalog.||)  e.extname OPERATOR(pg_catalog.||) ' DROP ' OPERATOR(pg_catalog.||) $3 OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) COALESCE(proc.proname OPERATOR(pg_catalog.||) '(' OPERATOR(pg_catalog.||) oidvectortypes(proc.proargtypes) OPERATOR(pg_catalog.||) ')' ,typ.typname, cd.relname, op.oprname,
+					cs.typname OPERATOR(pg_catalog.||) ' AS ' OPERATOR(pg_catalog.||) ct.typname OPERATOR(pg_catalog.||) ') ', opcname, opfname) OPERATOR(pg_catalog.||) ';' AS remove_command
 			FROM pg_catalog.pg_depend As d INNER JOIN pg_catalog.pg_extension As e
-				ON d.refobjid = e.oid INNER JOIN pg_catalog.pg_class As c ON
-					c.oid = d.classid
-					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid = d.objid
-					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid = d.objid
-					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid = d.objid
-					LEFT JOIN pg_operator As op ON op.oid = d.objid
-					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid = d.objid
-					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource = cs.oid
-					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget = ct.oid
-					LEFT JOIN pg_opclass As oc ON oc.oid = d.objid
-					LEFT JOIN pg_opfamily As ofa ON ofa.oid = d.objid
-			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND COALESCE(proc.proisagg, false) = $4;$sql$;
+				ON d.refobjid OPERATOR(pg_catalog.=) e.oid INNER JOIN pg_catalog.pg_class As c ON
+					c.oid OPERATOR(pg_catalog.=) d.classid
+					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_operator As op ON op.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource OPERATOR(pg_catalog.=) cs.oid
+					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget OPERATOR(pg_catalog.=) ct.oid
+					LEFT JOIN pg_catalog.pg_opclass As oc ON oc.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_opfamily As ofa ON ofa.oid OPERATOR(pg_catalog.=) d.objid
+			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND COALESCE(proc.proisagg, false) OPERATOR(pg_catalog.=) $4;$sql$;
 		ELSE -- for PostgreSQL 11 and above, they removed proc.proisagg among others and replaced with some func type thing
-					c.oid = d.classid
-			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND (proc.prokind = 'a')  = $4;$sql$;
+			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND (proc.prokind OPERATOR(pg_catalog.=) 'a')  OPERATOR(pg_catalog.=) $4;$sql$;
 		END IF;
 		FOR var_r IN EXECUTE var_sql_list  USING param_extension, var_class, param_type, var_is_aggregate
 		LOOP
-			var_sql := var_sql || var_r.remove_command || ';';
+			var_sql := var_sql OPERATOR(pg_catalog.||) var_r.remove_command OPERATOR(pg_catalog.||) ';';
 		END LOOP;
 		IF var_sql > '' THEN
 			EXECUTE var_sql;
@@ -85,7 +85,7 @@ CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_sta
   RETURNS boolean AS
 DECLARE
-	var_sql_ext text := 'ALTER EXTENSION ' || pg_catalog.quote_ident(param_extension) || ' ' || replace(param_statement, 'IF EXISTS', '');
+	var_sql_ext text := 'ALTER EXTENSION ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(param_extension) OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) pg_catalog.replace(param_statement, 'IF EXISTS', '');
 	var_result boolean := false;
 BEGIN
 	BEGIN
@@ -111,15 +111,15 @@ DECLARE
 BEGIN
 	WITH settings AS (
-		SELECT unnest(setconfig) config
+		SELECT pg_catalog.unnest(setconfig) config
 		FROM pg_catalog.pg_db_role_setting
-		WHERE setdatabase = (
+		WHERE setdatabase OPERATOR(pg_catalog.=) (
 			SELECT oid
 			FROM pg_catalog.pg_database
-			WHERE datname = current_database()
-		) and setrole = 0
+			WHERE datname OPERATOR(pg_catalog.=) pg_catalog.current_database()
+		) and setrole OPERATOR(pg_catalog.=) 0
-	SELECT regexp_replace(config, '^search_path=', '')
+	SELECT pg_catalog.regexp_replace(config, '^search_path=', '')
 	FROM settings WHERE config like 'search_path=%'
 	INTO var_cur_search_path;
@@ -129,23 +129,23 @@ BEGIN
 		SELECT reset_val
 		FROM pg_catalog.pg_settings
-		WHERE name = 'search_path';
+		WHERE name OPERATOR(pg_catalog.=) 'search_path';
 		RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
 	END IF;
-	IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
-		var_result := a_schema_name || ' already in database search_path';
+	IF var_cur_search_path LIKE '%' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name) OPERATOR(pg_catalog.||) '%' THEN
+		var_result := a_schema_name OPERATOR(pg_catalog.||) ' already in database search_path';
 	ELSE
-		var_cur_search_path := var_cur_search_path || ', '
-                        || pg_catalog.quote_ident(a_schema_name);
-		EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database())
-                              || ' SET search_path = ' || var_cur_search_path;
-		var_result := a_schema_name || ' has been added to end of database search_path ';
+		var_cur_search_path := var_cur_search_path OPERATOR(pg_catalog.||) ', '
+                       OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name);
+		EXECUTE 'ALTER DATABASE ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(pg_catalog.current_database())
+                             OPERATOR(pg_catalog.||) ' SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
+		var_result := a_schema_name OPERATOR(pg_catalog.||) ' has been added to end of database search_path ';
 	END IF;
-	EXECUTE 'SET search_path = ' || var_cur_search_path;
+	EXECUTE 'SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
   RETURN var_result;
 END
Summary of changes:
 extensions/postgis_extension_helper.sql | 96 ++++++++++++++++-----------------
 1 file changed, 48 insertions(+), 48 deletions(-)
hooks/post-receive
