[postgis-tickets] [PostGIS] #5164: "Server closed the connection unexpectedly" when installing PostGis on OS X with M1 chip
PostGIS trac at osgeo.org
Tue May 31 12:09:41 PDT 2022
with M1 chip
  Reporter:  chrisneve  |      Owner:  pramsey
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.2.2
 Component:  postgis    |    Version:  3.2.x
Resolution:             |   Keywords:
Old description:
> I am attempting to install Postgis on my newly created Postgresql DB and
> am running into issues doing so.
> **Environment**
> - OS X (Big Sur, 11.2.3 with a M1 chip)
> - Postgresql version: stable 14.3, installed with homebrew (more
> precisely, with the following syntax: arch -arm64 brew install
> postgresql)
> - Postgis version: stable 3.2.1, installed with homebrew (same)
> **What I'm trying to do**
> I want to install postgis on my postgresql database as such.
> Christophers-MacBook-Air:postgres root# psql -U chrisneve -d mydbname
> psql (14.3)
> Type "help" for help.
> mydbname=# create extension postgis;
> **The problem**
> The above snippet generates this error.
> server closed the connection unexpectedly
>     This probably means the server terminated abnormally
>     before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
> Before trying with psql directly, I executed the same command using
> DataGrip, which generated this error. (I also tried with the "cascade"
> mode: create extension postgis cascade, which generated the same result).
> mydbname.public> create extension postgis
> [2022-05-28 10:55:30] An I/O error occurred while sending to the backend.
> [2022-05-28 10:55:30] Unrecoverable error received, the connection is
> spoiled
> DataGrip also displayed a popup-style error saying this.
> Error [57P03]: FATAL: the database system is in recovery mode
> **What I tried**
>     I initially didn't know exactly where the error lied, so I started by
> asserting that the problem wasn't with the creation of extensions (for
> whatever reason).
> select * from mydbname.pg_catalog.pg_extension
> drop extension plpgsql
> create extension plpgsql
> This worked just fine; other extensions load fine.
>     Realising the issue seemed to come from Postgis, I tried removing and
> reinstalling Postgis, and even Postgresql, with homebrew, multiple times.
> It changed nothing.
>     I then wanted to install Postgis from a different location of
> https://postgis.net/install/#binary-installers for OS X, but all other
> install mechanisms (other than homebrew) told me not to mix with other
> installations, so I didn't try them.
> FWIW, I installed Postgis in the past on an identical DB on a Windows
> machine, so although I'm no Postgis expert I do know the install process.
> It would be much appreciated if a Postgis maintainer could help me out
> with this. Is this a new bug with the M1 chips? I can provide logs if it
> helps.
> Many thanks, Chris
New description:
 **Environment**
 precisely, with the following syntax: arch -arm64 brew install postgresql)
 psql (14.3)
 **The problem**
 spoiled
 **What I tried**
 whatever reason).
 It changed nothing.
 helps.
 Many thanks, Chris
Comment (by pramsey):
 This is almost certainly a packaging problem. You could disambiguate the
 source of the issue by compiling postgis from source and seeing if it
 works in that case (it probably will). Otherwise we lack the tools to
 debug this at the moment (no M1 system in hand).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5164#comment:2>
