[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-306-g132bf37ca
Tue Nov 1 07:53:54 PDT 2022
the project "PostGIS".
       via  132bf37caa0efc2f887a5e5b77c618a7def36f87 (commit)
       via  e14283eb0f0a871b445a553c8f21a71bf04defc8 (commit)
      from  c38561897f3a701f0d6606011e181043c94d1304 (commit)
revisions in full, below.
commit 132bf37caa0efc2f887a5e5b77c618a7def36f87
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Nov 1 08:18:45 2022 +0000
    Translated using Weblate (Japanese)
    Currently translated at 99.0% (301 of 304 strings)
    Translation: postgis/reference_relationship.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_relationshipxml/ja/
diff --git a/doc/po/ja/reference_relationship.xml.po b/doc/po/ja/reference_relationship.xml.po
index df7539c19..37b4e78d2 100644
--- a/doc/po/ja/reference_relationship.xml.po
+++ b/doc/po/ja/reference_relationship.xml.po
@@ -11,7 +11,7 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-10-23 01:21+0000\n"
-"PO-Revision-Date: 2022-10-28 01:30+0000\n"
+"PO-Revision-Date: 2022-11-01 14:52+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "reference_relationshipxml/ja/>\n"
@@ -2450,13 +2450,16 @@ msgstr ""
 #. Tag: para
 #: reference_relationship.xml:1232
-#, no-c-format
+#, fuzzy, no-c-format
 msgid ""
 "<code>1</code>: <emphasis role=\"bold\">OGC-Mod2</emphasis> - line endpoints "
 "are in the Boundary if they occur an odd number of times. This is the rule "
 "defined by the OGC SFS standard, and is the default for <function>ST_Relate</"
 "function>."
 msgstr ""
+"<code>1</code>: <emphasis role=\"bold\">OGC-Mod2</emphasis> - "
+"線の端点が奇数番目なら境界上にあるとみなします。これはOGC "
+"SFS標準で定義された規則で、<function>ST_Relate</function>のデフォルトです。"
 #. Tag: para
 #: reference_relationship.xml:1235
@@ -2470,22 +2473,29 @@ msgstr ""
 #. Tag: para
 #: reference_relationship.xml:1237
-#, no-c-format
 msgid ""
 "<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - "
 "endpoints are in the Boundary if they occur more than once. In other words, "
 "the boundary is all the \"attached\" or \"inner\" endpoints (but not the "
 "\"unattached/outer\" ones)."
 msgstr ""
+"<code>3</code>: <emphasis role=\"bold\">MultivalentEndpoint</emphasis> - 線の"
+"端点が境界線上にあるのが2回目以降の場合には、境界にあるとします。言い換えると"
+"、境界は「取り付けられた」または「内部の」端点 "
+"(「取り付けられてない」「外部の」端点ではない)です。"
 #. Tag: para
 #: reference_relationship.xml:1240
-#, no-c-format
 msgid ""
 "<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - "
 "endpoints are in the Boundary if they occur only once. In other words, the "
 "boundary is all the \"unattached\" or \"outer\" endpoints."
 msgstr ""
+"<code>4</code>: <emphasis role=\"bold\">MonovalentEndpoint</emphasis> - 線の"
+"端点が境界線上にあるのが1回目の場合に限って、境界にあるとします。言い換えると"
+"「属していない」または「外部」の端点です。"
 #. Tag: para
 #: reference_relationship.xml:1245
commit e14283eb0f0a871b445a553c8f21a71bf04defc8
Date:   Tue Nov 1 08:16:52 2022 +0000
    Currently translated at 100.0% (532 of 532 strings)
    Translation: postgis/using_postgis_dataman.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/using_postgis_datamanxml/ja/
diff --git a/doc/po/ja/using_postgis_dataman.xml.po b/doc/po/ja/using_postgis_dataman.xml.po
index 30217fc5d..fe61cc47a 100644
--- a/doc/po/ja/using_postgis_dataman.xml.po
+++ b/doc/po/ja/using_postgis_dataman.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
-"PO-Revision-Date: 2022-09-12 12:43+0000\n"
 "using_postgis_datamanxml/ja/>\n"
@@ -16,7 +16,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
-"X-Generator: Weblate 4.13.1\n"
+"X-Generator: Weblate 4.14.1\n"
 #. Tag: title
 #: using_postgis_dataman.xml:3
@@ -2794,6 +2794,13 @@ msgid ""
 "linkend=\"ST_TransformPipeline\"/>. Geometry returned from functions has the "
 "same SRS as the input geometries."
 msgstr ""
+"二つのジオメトリを処理する空間関数 (<link linkend=\"Overlay_Functions\""
+">オーバレイ関数</link> 、<link linkend=\"Spatial_Relationships\""
+">関係関数</link>など)の入力ジオメトリは、同じ空間参照系である "
+"(同じSRIDを持つ)必要があります。<xref linkend=\"ST_Transform\"/>や<xref "
+"linkend=\"ST_TransformPipeline\"/>を使うことで、ジオメトリデータを異なる空間"
+"参照系に変換できます。関数から返されるジオメトリは、入力ジオメトリと同じ空間"
+"参照系になります。"
 #. Tag: title
 #: using_postgis_dataman.xml:1291
Summary of changes:
 doc/po/ja/reference_relationship.xml.po | 18 ++++++++++++++----
 doc/po/ja/using_postgis_dataman.xml.po  | 11 +++++++++--
 2 files changed, 23 insertions(+), 6 deletions(-)
hooks/post-receive
