[postgis-tickets] [PostGIS] #5264: make install error when compiling from source while processing 'topology' subdirectory for version > 3.1.7
PostGIS trac at osgeo.org
Thu Nov 3 01:17:26 PDT 2022
  Reporter:  louisd    |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.3.2
 Component:  topology  |    Version:  3.3.x
Resolution:            |   Keywords:  make install topology error
Comment (by strk):
 The Makefile is generated at ./configure time from Makefile.in so please
 modify the latter. In order to check if it creates new problems you could
 file a pull request on git.osgeo.org/gitea/postgis/postgis which would
 trigger tests run automatically with the new code.  Good catch !
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5264#comment:8>
