[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.3-25-gc2a5b06ad
Thu Nov 3 05:52:03 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  c2a5b06ade6968ec615ef8ee1f6e66e80b83b515 (commit)
      from  437540ccd58ba7bb398d2dac75da3f6f5dddc8ad (commit)
revisions in full, below.
commit c2a5b06ade6968ec615ef8ee1f6e66e80b83b515
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Oct 28 18:35:05 2022 +0200
    Fix error in topology import of self-intersecting rings
    Closes #5081 in 3.2 branch (3.2.4dev)
    Includes regression testcase
diff --git a/NEWS b/NEWS
index 0be5c010a..81c07704b 100644
--- a/NEWS
+++ b/NEWS
@@ -15,6 +15,7 @@ Proj 6.1+, and PostgreSQL 14+.
   - #5255, GH702, Remove forced static linking on raster2pgsql (Thomas Petazzoni)
   - #4648, Check function ownership at extension packaging time (Sandro Santilli)
   - #5241, Crash on ST_SnapToGrid with empty multis (Regina Obe)
+  - #5081, Fix error in topology import of self-intersecting rings (Sandro Santilli)
 PostGIS 3.2.3
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 97e0515eb..16d64db81 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -18,7 +18,7 @@
- * Copyright (C) 2015-2021 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2015-2022 Sandro Santilli <strk at kbt.io>
@@ -5847,9 +5847,22 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     lwgeom_free(xset);
     xset = tmp;
+     * Here we union the (linemerged) intersection with
+     * the difference (new lines)
+    LWDEBUG(1, "Unioning difference and (linemerged) intersection");
+    noded = lwgeom_union(diff, xset);
+    LWDEBUGG(1, noded, "Diff-Xset Unioned");
+    lwgeom_free(xset);
+    lwgeom_free(diff);
+    /* will not release the geoms array */
+    lwcollection_release(col);
     if ( input_was_closed )
-      LWLINE *scrolled = lwgeom_as_lwline(xset);
+      LWLINE *scrolled = lwgeom_as_lwline(noded);
       if (scrolled) {
         if ( lwline_is_closed(scrolled) ) {
           ptarray_scroll_in_place(scrolled->points, &originalStartPoint);
@@ -5864,18 +5877,6 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
-     * Here we union the (linemerged) intersection with
-     * the difference (new lines)
-    LWDEBUG(1, "Unioning difference and (linemerged) intersection");
-    noded = lwgeom_union(diff, xset);
-    LWDEBUGG(1, noded, "Diff-Xset Unioned");
-    lwgeom_free(xset);
-    lwgeom_free(diff);
-    /* will not release the geoms array */
-    lwcollection_release(col);
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 60cabfe26..23587686b 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -467,3 +467,26 @@ AND NOT ST_Equals(
 SELECT NULL FROM topology.DropTopology('b4941');
+-- See https://trac.osgeo.org/postgis/ticket/5081
+SELECT NULL FROM CreateTopology('b5081');
+SELECT 'b5081.0', 'E' || TopoGeo_addLinestring('b5081', $$
+  LINESTRING(0 0, 10 10,10 -10,0 0)
+SELECT 'b5081.1', count(*) > 1 FROM (
+  SELECT TopoGeo_addLinestring('b5081', $$
+    LINESTRING(
+      -10 0,
+      0 0, 10 10,10 -10,0 0,
+      -10 0
+) foo;
+SELECT 'b5081', 'dangling_edges', count(*)
+  FROM b5081.edge
+  WHERE left_face = right_face;
+SELECT 'b5081', 'faces', count(*)
+  FROM b5081.face
+  WHERE face_id > 0;
+SELECT NULL FROM topology.DropTopology('b5081');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 8b9e06aae..26b18f000 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -219,3 +219,7 @@ t2175.3|1
 b4941|outer_ring|1
 b4941|inner_ring|1
 b4941|crossing_line|5
+b5081.0|E1
+b5081.1|t
+b5081|dangling_edges|1
+b5081|faces|1
Summary of changes:
 NEWS                                               |  1 +
 liblwgeom/lwgeom_topo.c                            | 29 +++++++++++-----------
 topology/test/regress/topogeo_addlinestring.sql    | 23 +++++++++++++++++
 .../test/regress/topogeo_addlinestring_expected    |  4 +++
 4 files changed, 43 insertions(+), 14 deletions(-)
hooks/post-receive
