[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-316-g41a87d30f
Thu Nov 3 12:48:01 PDT 2022
the project "PostGIS".
       via  41a87d30fb58110e73b0d05978ca9701fe2b17b2 (commit)
      from  ecc2bdd8b6b25cbdb12ac4e3b0e0ca0602dd81ee (commit)
revisions in full, below.
commit 41a87d30fb58110e73b0d05978ca9701fe2b17b2
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Nov 3 20:45:58 2022 +0100
    Fix 2.5d topology building regression (geometrically non-closed)
    References #5234 in master branch (3.4.0dev)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index a4ca8532f..5988e5a67 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -1912,7 +1912,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
     return -2;
   const POINTARRAY *pa = shell->rings[0];
-  if ( ! ptarray_is_closed(pa) )
+  if ( ! ptarray_is_closed_2d(pa) )
     lwpoly_free(shell);
     lwfree( signed_edge_ids );
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index e9f4b6f95..84fa46a16 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -490,3 +490,14 @@ SELECT 'b5081', 'faces', count(*)
   FROM b5081.face
   WHERE face_id > 0;
 SELECT NULL FROM topology.DropTopology('b5081');
+-- See https://trac.osgeo.org/postgis/ticket/5234
+BEGIN;
+SELECT NULL FROM topology.createtopology('b5234', 0, 0, TRUE);
+SELECT 'b5234.0', count(*) FROM
+TopoGeo_addLinestring('b5234',
+  'LINESTRING(0 0 0, 10 0 1, 10 10 3)', 0);
+SELECT 'b5234.1', count(*) FROM
+  'LINESTRING(10 10 3, 5 0 0.8)', 0);
+ROLLBACK;
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 26b18f000..de9b8d8fe 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -223,3 +223,5 @@ b5081.0|E1
 b5081.1|t
 b5081|dangling_edges|1
 b5081|faces|1
+b5234.0|1
+b5234.1|1
Summary of changes:
 liblwgeom/lwgeom_topo.c                              |  2 +-
 topology/test/regress/topogeo_addlinestring.sql      | 11 +++++++++++
 topology/test/regress/topogeo_addlinestring_expected |  2 ++
 3 files changed, 14 insertions(+), 1 deletion(-)
hooks/post-receive
