[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.3-26-g7f5f96436
Thu Nov 3 13:02:58 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  7f5f964361b89d111060f4dc6620979d783fe09e (commit)
      from  c2a5b06ade6968ec615ef8ee1f6e66e80b83b515 (commit)
revisions in full, below.
commit 7f5f964361b89d111060f4dc6620979d783fe09e
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Nov 3 20:45:58 2022 +0100
    Fix 2.5d topology building regression (geometrically non-closed)
    References #5234 in 3.2 branch (3.2.4dev)
diff --git a/NEWS b/NEWS
index 81c07704b..b573e3803 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,7 @@ Proj 6.1+, and PostgreSQL 14+.
   - #4648, Check function ownership at extension packaging time (Sandro Santilli)
   - #5241, Crash on ST_SnapToGrid with empty multis (Regina Obe)
   - #5081, Fix error in topology import of self-intersecting rings (Sandro Santilli)
+  - #5234, Fix 2.5d topology building regression (Sandro Santilli)
 PostGIS 3.2.3
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 16d64db81..2e862d6dc 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -1906,7 +1906,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
     return -2;
   const POINTARRAY *pa = shell->rings[0];
-  if ( ! ptarray_is_closed(pa) )
+  if ( ! ptarray_is_closed_2d(pa) )
     lwpoly_free(shell);
     lwfree( signed_edge_ids );
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 23587686b..05b98d538 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -490,3 +490,14 @@ SELECT 'b5081', 'faces', count(*)
   FROM b5081.face
   WHERE face_id > 0;
 SELECT NULL FROM topology.DropTopology('b5081');
+-- See https://trac.osgeo.org/postgis/ticket/5234
+BEGIN;
+SELECT NULL FROM topology.createtopology('b5234', 0, 0, TRUE);
+SELECT 'b5234.0', count(*) FROM
+TopoGeo_addLinestring('b5234',
+  'LINESTRING(0 0 0, 10 0 1, 10 10 3)', 0);
+SELECT 'b5234.1', count(*) FROM
+  'LINESTRING(10 10 3, 5 0 0.8)', 0);
+ROLLBACK;
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 26b18f000..de9b8d8fe 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -223,3 +223,5 @@ b5081.0|E1
 b5081.1|t
 b5081|dangling_edges|1
 b5081|faces|1
+b5234.0|1
+b5234.1|1
Summary of changes:
 NEWS                                                 |  1 +
 liblwgeom/lwgeom_topo.c                              |  2 +-
 topology/test/regress/topogeo_addlinestring.sql      | 11 +++++++++++
 topology/test/regress/topogeo_addlinestring_expected |  2 ++
 4 files changed, 15 insertions(+), 1 deletion(-)
hooks/post-receive
