[postgis-tickets] [PostGIS] #5282: boundary, relate_bnr regression on GEOS 3.9.4
PostGIS trac at osgeo.org
Sat Nov 5 21:26:23 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.1.8
Component:  postgis  |    Version:  3.1.x
 Keywords:           |
 Debbie is showing this when testing PostGIS 3.1.8 against GEOS 3.9.4dev
 https://debbie.postgis.net/job/PostGIS_Regress/23080/console
 23:56:51 PostgreSQL 11.17 on x86_64-pc-linux-gnu, compiled by gcc (Debian
 10.2.1-6) 10.2.1 20210110, 64-bit
 23:56:51   Postgis 3.1.8dev - (3.1.7-21-gfe5eb4f54) - 2022-11-06 03:52:59
 23:56:51   scripts 3.1.8dev 3.1.7-21-gfe5eb4f54
 23:56:51   raster scripts 3.1.8dev 3.1.7-21-gfe5eb4f54
 23:56:51   GEOS: 3.9.4dev-CAPI-1.14.4
 23:56:51   PROJ: 7.2.1
 23:56:51   SFCGAL: 1.3.8
 23:56:51   GDAL: GDAL 3.4.3, released 2022/04/22
 23:56:51  ./regress/core/boundary .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_1_pg11w64/test_4_diff)
 23:56:51
 23:56:51 --- ./regress/core/boundary_expected   2021-01-14
 01:11:03.006011680 +0000
 23:56:51 +++ /var/lib/jenkins/workspace/postgis/tmp/3_1_pg11w64/test_4_out
 2022-11-06 03:56:51.939427452 +0000
 23:56:51 @@ -1,5 +1,5 @@
 23:56:51  MULTIPOINT(1 1,-1 1)
 23:56:51  LINESTRING(1 1,0 0,-1 1,1 1)
 23:56:51  LINESTRING(1 1 1,0 0 1,-1 1 1,1 1 1)
 23:56:51 -MULTIPOINT(-1 1 1,1 1 0.75)
 23:56:51 +MULTIPOINT(-1 1 1,1 1 1)
 23:56:51
 23:57:43  ./regress/core/relate_bnr .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_1_pg11w64/test_89_diff)
 23:57:44
 23:57:44 --- ./regress/core/relate_bnr_expected 2021-01-14
 01:11:03.070011681 +0000
 23:57:44 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_1_pg11w64/test_89_out
 2022-11-06 03:57:44.017813759 +0000
 23:57:44 @@ -28,7 +28,7 @@
 23:57:44  28|10FF0FFF2|10FF0FFF2|1FFFFFFF2|10FF0FFF2
 23:57:44  29|FF1FF0102|FF1FF0102|FF1FF0102|FF1FF0102
 23:57:44  30|FF1FF0102|FF1FF0102|FF1FFF1F2|FF1FF0102
 23:57:44 -31|FF1FF01F2|FF1FF01F2|FF1FF01F2|FF1FF01F2
 23:57:44 +31|FF1FF01F2|FF1FF0102|FF1FF0102|FF1FF01F2
 23:57:44  32|FF1FF01F2|FF1FF0102|FF1FFF1F2|FF1FF01F2
 23:57:44  33|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
 23:57:44  34|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
 23:57:44
 My local GEOS is 3.9.2ish and doesn't show this and sadly winnie's geos
 3.9 builds are broken so couldn't grab a newer binary from her to confirm.
 I know we changed the behavior of relate_bnr, so that one I'll just take
 out the test as I did in master.
 The boundary one I don't recall but might be related.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5282>
