[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.7-19-g99fda1c0a
Sat Nov 5 22:18:48 PDT 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  99fda1c0ac6b43d62dcaa7f37fe1c0562654f7ce (commit)
      from  9bf759d9d7203534de53fcfe827fee5e4b30bfdb (commit)
revisions in full, below.
commit 99fda1c0ac6b43d62dcaa7f37fe1c0562654f7ce
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 6 01:17:38 2022 -0400
    Take out relate_bnr and boundary tests that
    no longer agree with newer GEOS micros
    References #5282 for PostGIS 3.0.8
diff --git a/regress/core/boundary.sql b/regress/core/boundary.sql
index 68dc883d8..c2c4f83d5 100644
--- a/regress/core/boundary.sql
+++ b/regress/core/boundary.sql
@@ -1,5 +1,6 @@
 SELECT ST_AsText(ST_Boundary(ST_GeomFromText('LINESTRING(1 1,0 0, -1 1)')));
 SELECT ST_AsText(ST_Boundary(ST_GeomFromText('POLYGON((1 1,0 0, -1 1, 1 1))')));
 SELECT ST_AsEWKT(ST_Boundary(ST_GeomFromEWKT('POLYGON((1 1 1,0 0 1, -1 1 1, 1 1 1))')));
-SELECT ST_AsEWKT(ST_Boundary(ST_GeomFromEWKT('MULTILINESTRING((1 1 1,0 0 0.5, -1 1 1),(1 1 0.5,0 0 0.5, -1 1 0.5, 1 1 0.5) )')));
+-- no longer matches old answer in newer GEOS micros from GEOS 3.9.4
+-- SELECT ST_AsEWKT(ST_Boundary(ST_GeomFromEWKT('MULTILINESTRING((1 1 1,0 0 0.5, -1 1 1),(1 1 0.5,0 0 0.5, -1 1 0.5, 1 1 0.5) )')));
 SELECT ST_AsText(ST_Boundary(ST_GeomFromText('TRIANGLE((1 1,0 0, -1 1, 1 1))')));
diff --git a/regress/core/boundary_expected b/regress/core/boundary_expected
index 8105f0bcb..0b9dd701b 100644
--- a/regress/core/boundary_expected
+++ b/regress/core/boundary_expected
@@ -1,5 +1,4 @@
 MULTIPOINT(1 1,-1 1)
 LINESTRING(1 1,0 0,-1 1,1 1)
 LINESTRING(1 1 1,0 0 1,-1 1 1,1 1 1)
-MULTIPOINT(-1 1 1,1 1 0.75)
diff --git a/regress/core/relate_bnr.sql b/regress/core/relate_bnr.sql
index 2c5d57447..378a8e3ba 100644
--- a/regress/core/relate_bnr.sql
+++ b/regress/core/relate_bnr.sql
@@ -28,7 +28,8 @@ SELECT '27', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as
 SELECT '28', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(0 0,60 0,60 60,60 0,120 0)'::geometry as a, 'MULTILINESTRING((0 0,60 0),(60 0,120 0),(60 0,60 60))'::geometry as b) as f;
 SELECT '29', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(140 300,220 160,260 200,240 260)'::geometry as b) as f;
 SELECT '30', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(60 40,140 40,140 160,0 160)'::geometry as b) as f;
-SELECT '31', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(140 280,240 280,240 180,140 180,140 280)'::geometry as b) as f;
+-- Taken out because answer changes in GEOS 3.9.4, 3.10.4, 3.11.1, 3.12.0, and no need to test this border case in PostGIS
+--SELECT '31', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(60 0,20 80,100 80,80 120,40 140)'::geometry as a, 'LINESTRING(140 280,240 280,240 180,140 180,140 280)'::geometry as b) as f;
 SELECT '32', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(140 0,0 0,40 60,0 120,60 200,220 160,220 40)'::geometry as a, 'LINESTRING(80 140,180 100,160 40,100 40,60 100,80 140)'::geometry as b) as f;
 SELECT '33', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(20 20,80 80)'::geometry as a, 'LINESTRING(20 20,80 80)'::geometry as b) as f;
 SELECT '34', st_relate(a,b,1) as r1, st_relate(a,b,2) as r2, st_relate(a,b,3) as r3, st_relate(a,b,4) as r4 FROM (select 'LINESTRING(40 40,160 160,200 60,60 140)'::geometry as a, 'LINESTRING(40 40,160 160,200 60,60 140)'::geometry as b) as f;
diff --git a/regress/core/relate_bnr_expected b/regress/core/relate_bnr_expected
index 89dabee7d..6f57aeaec 100644
--- a/regress/core/relate_bnr_expected
+++ b/regress/core/relate_bnr_expected
@@ -28,7 +28,6 @@
 28|10FF0FFF2|10FF0FFF2|1FFFFFFF2|10FF0FFF2
 29|FF1FF0102|FF1FF0102|FF1FF0102|FF1FF0102
 30|FF1FF0102|FF1FF0102|FF1FFF1F2|FF1FF0102
-31|FF1FF01F2|FF1FF01F2|FF1FF01F2|FF1FF01F2
 32|FF1FF01F2|FF1FF0102|FF1FFF1F2|FF1FF01F2
 33|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
 34|1FFF0FFF2|1FFF0FFF2|1FFFFFFF2|1FFF0FFF2
Summary of changes:
 regress/core/boundary.sql        | 3 ++-
 regress/core/boundary_expected   | 1 -
 regress/core/relate_bnr.sql      | 3 ++-
 regress/core/relate_bnr_expected | 1 -
 4 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
