[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-324-gf3dfb23ae
Tue Nov 8 01:30:12 PST 2022
the project "PostGIS".
       via  f3dfb23ae2815e7a709d4933303a234085ed55db (commit)
      from  bcca50bd5278ea3181df3f2114b2bfe4f94b64db (commit)
revisions in full, below.
commit f3dfb23ae2815e7a709d4933303a234085ed55db
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Nov 8 10:25:08 2022 +0100
    RenameTopology function
    Closes #5283
    Includes documentation and regress test
diff --git a/NEWS b/NEWS
index 6dfb6e337..d03b84bfd 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ xxxx/xx/xx
   - New install-extension-upgrades command in postgis script (Sandro Santilli)
   - #5257, #5261, #5277, Support changes for PostgreSQL 16 (Regina Obe)
   - #5006, GH705, ST_Transform: Support PROJ pipelines (Robert Coup, Koordinates)
+  - #5283, RenameTopology (Sandro Santilli)
 * Enhancements *
   - #5194, do not update system catalogs from postgis_extensions_upgrade (Sandro Santilli)
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 55eb59eec..062bf9393 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -393,6 +393,54 @@ SELECT topology.AddTopoGeometryColumn('ri_topo', 'ri', 'roads', 'topo', 'LINE');
 				<para><xref linkend="DropTopoGeometryColumn"/></para>
 			</refsection>
 		</refentry>
+		<refentry id="RenameTopology">
+			<refnamediv>
+				<refname>RenameTopology</refname>
+				<refpurpose>Renames a topology</refpurpose>
+			</refnamediv>
+			<refsynopsisdiv>
+				<funcsynopsis>
+					<funcprototype>
+						<funcdef>varchar <function>RenameTopology</function></funcdef>
+						<paramdef><type>varchar </type> <parameter>old_name</parameter></paramdef>
+						<paramdef><type>varchar </type> <parameter>new_name</parameter></paramdef>
+					</funcprototype>
+				</funcsynopsis>
+			</refsynopsisdiv>
+			<refsection>
+                <title>Description</title>
+                <para>
+Renames a topology schema updating its metadata record in
+topology.topology.
+		</para>
+                <!-- use this format if new function -->
+                <para>Availability: 3.4.0</para>
+			</refsection>
+			<refsection>
+				<title>Examples</title>
+				<para>
+This example renames a topology from <varname>topo_stage</varname> to
+<varname>topo_prod</varname>.
+				</para>
+				<programlisting>SELECT topology.RenameTopology('topo_stage', 'topo_prod');</programlisting>
+			</refsection>
+			<!-- Optionally add a "See Also" section -->
+			<refsection>
+				<title>See Also</title>
+				<para>>
+                    <xref linkend="CopyTopology" />
+                </para>
+			</refsection>
+		</refentry>
 		<refentry id="DropTopoGeometryColumn">
 			<refnamediv>
 				<refname>DropTopoGeometryColumn</refname>
@@ -1156,7 +1204,11 @@ This example makes a backup of a topology called ma_topo
 			<refsection>
-				<para><xref linkend="spatial_ref_sys"/>, <xref linkend="CreateTopology" /></para>
+				<para>
+                    <xref linkend="spatial_ref_sys"/>,
+                    <xref linkend="CreateTopology" />,
+                    <xref linkend="RenameTopology" />
+                </para>
 			</refsection>
 		</refentry>
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 6420be1e2..fc6ffefd4 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -139,6 +139,7 @@ topology.sql: \
 	sql/manage/FindLayer.sql.in \
 	sql/manage/FindTopology.sql.in \
 	sql/manage/ManageHelper.sql.in \
+	sql/manage/RenameTopology.sql.in \
 	sql/manage/ValidateTopology.sql.in \
 	sql/manage/ValidateTopologyRelation.sql.in \
 	sql/topoelement/topoelement_agg.sql.in \
diff --git a/topology/sql/manage/RenameTopology.sql.in b/topology/sql/manage/RenameTopology.sql.in
new file mode 100644
index 000000000..2364340e4
--- /dev/null
+++ b/topology/sql/manage/RenameTopology.sql.in
@@ -0,0 +1,43 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- RenameTopology(old_name, new_name)
+-- Renames a topology, returns new name.
+CREATE OR REPLACE FUNCTION topology.RenameTopology(old_name varchar, new_name varchar)
+RETURNS varchar
+AS
+$BODY$
+DECLARE
+  sql text;
+BEGIN
+  sql := format(
+    'ALTER SCHEMA %I RENAME TO %I',
+    old_name, new_name
+  EXECUTE sql;
+  sql := format(
+    'UPDATE topology.topology SET name = %L WHERE name = %L',
+    new_name, old_name
+  EXECUTE sql;
+  RETURN new_name;
+END
+$BODY$
+LANGUAGE 'plpgsql' VOLATILE STRICT;
+--} RenameTopology
diff --git a/topology/test/regress/renametopology.sql b/topology/test/regress/renametopology.sql
index 000000000..e19ff01b8
--- /dev/null
+++ b/topology/test/regress/renametopology.sql
@@ -0,0 +1,6 @@
+BEGIN;
+SELECT NULL FROM topology.CreateTopology('topo');
+SELECT 't1', topology.RenameTopology('topo', 'topo with space');
+SELECT 't2', topology.RenameTopology('topo with space', 'topo with MixedCase');
+SELECT 't2', topology.RenameTopology('topo with MixedCase', 'topo');
+ROLLBACK;
diff --git a/topology/test/regress/renametopology_expected b/topology/test/regress/renametopology_expected
index 000000000..bae8b6092
--- /dev/null
+++ b/topology/test/regress/renametopology_expected
@@ -0,0 +1,3 @@
+t1|topo with space
+t2|topo with MixedCase
+t2|topo
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 27ae06595..197f72274 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1415,6 +1415,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 #include "sql/manage/CopyTopology.sql.in"
 #include "sql/manage/FindTopology.sql.in"
 #include "sql/manage/FindLayer.sql.in"
+#include "sql/manage/RenameTopology.sql.in"
 #include "sql/manage/ValidateTopology.sql.in"
 #include "sql/manage/ValidateTopologyRelation.sql.in"
Summary of changes:
 NEWS                                          |  1 +
 doc/extras_topology.xml                       | 54 ++++++++++++++++++++++++++-
 topology/Makefile.in                          |  1 +
 topology/sql/manage/RenameTopology.sql.in     | 43 +++++++++++++++++++++
 topology/test/regress/renametopology.sql      |  6 +++
 topology/test/regress/renametopology_expected |  3 ++
 topology/topology.sql.in                      |  1 +
 7 files changed, 108 insertions(+), 1 deletion(-)
 create mode 100644 topology/sql/manage/RenameTopology.sql.in
 create mode 100644 topology/test/regress/renametopology.sql
 create mode 100644 topology/test/regress/renametopology_expected
hooks/post-receive
