[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-327-gdbd2b5f81
Tue Nov 8 08:37:06 PST 2022
the project "PostGIS".
       via  dbd2b5f819afd76322f0becd6e559d1ce4190f68 (commit)
       via  e34553495fda3f3b005a33349dc19ffa50d4724a (commit)
      from  bb4786f3ed3c9966635e0ea9c6f410a5058b64fe (commit)
revisions in full, below.
commit dbd2b5f819afd76322f0becd6e559d1ce4190f68
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Nov 8 17:33:06 2022 +0100
    RenameTopoGeometryColumn function
    Closes #5286.
    Includes docs and regress test
diff --git a/NEWS b/NEWS
index d03b84bfd..48d3b44ef 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,7 @@ xxxx/xx/xx
   - #5257, #5261, #5277, Support changes for PostgreSQL 16 (Regina Obe)
   - #5006, GH705, ST_Transform: Support PROJ pipelines (Robert Coup, Koordinates)
   - #5283, RenameTopology (Sandro Santilli)
+  - #5286, RenameTopoGeometryColumn (Sandro Santilli)
 * Enhancements *
   - #5194, do not update system catalogs from postgis_extensions_upgrade (Sandro Santilli)
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 062bf9393..3e865a854 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -353,6 +353,56 @@ SELECT topology.AddTopoGeometryColumn('ri_topo', 'ri', 'roads', 'topo', 'LINE');
 				</para>
 			</refsection>
 		</refentry>
+	    <refentry id="RenameTopoGeometryColumn">
+			<refnamediv>
+				<refname>RenameTopoGeometryColumn</refname>
+				<refpurpose>Renames a topogeometry column</refpurpose>
+			</refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                     <funcprototype>
+                        <funcdef>topology.layer <function>RenameTopoGeometryColumn</function></funcdef>
+                        <paramdef><type>regclass </type>
+                        <parameter>layer_table</parameter></paramdef>
+                        <paramdef><type>name </type>
+                        <parameter>feature_column</parameter></paramdef>
+                        <parameter>new_name</parameter></paramdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+			<refsection>
+                <title>Description</title>
+                <para>
+This function changes the name of an existing TopoGeometry column
+ensuring metadata information about it is updated accordingly.
+                </para>
+                <!-- use this format if new function -->
+                <para>Availability: 3.4.0</para>
+			</refsection>
+			<refsection>
+				<title>Examples</title>
+				<programlisting>
+SELECT topology.RenameTopoGeometryColumn('public.parcels', 'topogeom', 'tgeom');
+                </programlisting>
+			</refsection>
+			<!-- Optionally add a "See Also" section -->
+			<refsection>
+				<title>See Also</title>
+				<para>
+				  <xref linkend="AddTopoGeometryColumn"/>,
+				  <xref linkend="RenameTopology"/>
+				</para>
+			</refsection>
+		</refentry>
 		<refentry id="DropTopology">
 			<refnamediv>
 				<refname>DropTopology</refname>
@@ -437,7 +487,8 @@ This example renames a topology from <varname>topo_stage</varname> to
 				<para>>
-                    <xref linkend="CopyTopology" />
+                    <xref linkend="CopyTopology" />,
+                    <xref linkend="RenameTopoGeometryColumn" />
                 </para>
 			</refsection>
 		</refentry>
diff --git a/topology/sql/manage/RenameTopoGeometryColumn.sql.in b/topology/sql/manage/RenameTopoGeometryColumn.sql.in
new file mode 100644
index 000000000..512549210
--- /dev/null
+++ b/topology/sql/manage/RenameTopoGeometryColumn.sql.in
@@ -0,0 +1,75 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+--  RenameTopoGeometryColumn(regclass, old_colname, new_colname)
+-- Rename a TopoGeometry column in a table.
+-- Returns the new topology.layer record
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION topology.RenameTopoGeometryColumn(layer_table regclass, feature_column name, new_name name)
+  RETURNS topology.layer
+AS
+DECLARE
+  layer topology.layer;
+  sql text;
+BEGIN
+  layer := topology.FindLayer(layer_table, feature_column);
+  IF layer IS NULL THEN
+    RAISE EXCEPTION 'Layer %.% does not exist', layer_table, feature_column;
+  END IF;
+  -- Rename TopoGeometry column
+  sql := format('ALTER TABLE %s RENAME %I to %I',
+    layer_table, feature_column, new_name);
+  EXECUTE sql;
+  -- Update topology.layer record
+  -- Temporarely disable integrity check
+  ALTER TABLE topology.layer DISABLE TRIGGER layer_integrity_checks;
+  sql := format(
+      'UPDATE topology.layer SET feature_column = %L '
+      'WHERE topology_id = $1 and layer_id = $2',
+      new_name
+  EXECUTE sql USING layer.topology_id, layer.layer_id;
+  -- Re-enable integrity check
+  -- TODO: tweak layer_integrity_checks to allow this
+  ALTER TABLE topology.layer ENABLE TRIGGER layer_integrity_checks;
+  -- Rename constraints on TopoGeom column
+  sql := format(
+    'ALTER TABLE %s RENAME CONSTRAINT '
+    '"check_topogeom_%s" TO "check_topogeom_%s"',
+  EXECUTE sql;
+  layer.feature_column = new_name;
+  RETURN layer;
+END;
+LANGUAGE 'plpgsql' VOLATILE;
+--} RenameTopoGeometryColumn
diff --git a/topology/test/regress/renametopogeometrycolumn.sql b/topology/test/regress/renametopogeometrycolumn.sql
index 000000000..e78b6f93a
--- /dev/null
+++ b/topology/test/regress/renametopogeometrycolumn.sql
@@ -0,0 +1,8 @@
+BEGIN;
+SELECT NULL FROM createtopology('tt');
+CREATE TABLE tt.f(id integer);
+SELECT NULL FROM addtopogeometrycolumn('tt','tt','f','tg','POINT');
+SELECT 't0', layer_id, feature_column FROM topology.layer;
+SELECT 't1', layer_id, feature_column FROM renametopogeometrycolumn('tt.f', 'tg', 'the TopoGeom');
+SELECT 't2', layer_id, feature_column FROM renametopogeometrycolumn('tt.f', 'the TopoGeom', 'tgeom');
+ROLLBACK;
diff --git a/topology/test/regress/renametopogeometrycolumn_expected b/topology/test/regress/renametopogeometrycolumn_expected
index 000000000..68362fb59
--- /dev/null
+++ b/topology/test/regress/renametopogeometrycolumn_expected
@@ -0,0 +1,3 @@
+t0|1|tg
+t1|1|the TopoGeom
+t2|1|tgeom
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 98712c40d..3ba97b59b 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -46,8 +46,9 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/legacy_query.sql \
 	$(top_srcdir)/topology/test/regress/legacy_validate.sql \
 	$(top_srcdir)/topology/test/regress/polygonize.sql \
-	$(top_srcdir)/topology/test/regress/renametopology.sql \
 	$(top_srcdir)/topology/test/regress/removeunusedprimitives.sql \
+	$(top_srcdir)/topology/test/regress/renametopology.sql \
+	$(top_srcdir)/topology/test/regress/renametopogeometrycolumn.sql \
 	$(top_srcdir)/topology/test/regress/sqlmm.sql \
 	$(top_srcdir)/topology/test/regress/st_addedgemodface.sql \
 	$(top_srcdir)/topology/test/regress/st_addedgenewfaces.sql \
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 197f72274..1160c58fe 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1410,6 +1410,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 --general management --
 #include "sql/manage/ManageHelper.sql.in"
 #include "sql/manage/AddTopoGeometryColumn.sql.in"
+#include "sql/manage/RenameTopoGeometryColumn.sql.in"
 #include "sql/manage/CreateTopology.sql.in"
 #include "sql/manage/TopologySummary.sql.in"
 #include "sql/manage/CopyTopology.sql.in"
commit e34553495fda3f3b005a33349dc19ffa50d4724a
Date:   Tue Nov 8 17:05:46 2022 +0100
    Add missing sql/manage/ dependencies on topology.sql
diff --git a/topology/Makefile.in b/topology/Makefile.in
index fc6ffefd4..89dc31e00 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -134,14 +134,16 @@ topology.sql: \
 	sql/query/GetRingEdges.sql.in \
 	sql/query/GetNodeEdges.sql.in \
 	sql/query/GetFaceContainingPoint.sql.in \
-	sql/manage/TopologySummary.sql.in \
+	sql/manage/AddTopoGeometryColumn.sql.in \
 	sql/manage/CopyTopology.sql.in \
+	sql/manage/CreateTopology.sql.in \
 	sql/manage/FindLayer.sql.in \
 	sql/manage/FindTopology.sql.in \
 	sql/manage/ManageHelper.sql.in \
 	sql/manage/RenameTopology.sql.in \
-	sql/manage/ValidateTopology.sql.in \
+	sql/manage/TopologySummary.sql.in \
 	sql/manage/ValidateTopologyRelation.sql.in \
+	sql/manage/ValidateTopology.sql.in \
 	sql/topoelement/topoelement_agg.sql.in \
 	sql/topogeometry/type.sql.in \
 	sql/topogeometry/totopogeom.sql.in \
Summary of changes:
 NEWS                                               |  1 +
 doc/extras_topology.xml                            | 53 ++++++++++++++-
 topology/Makefile.in                               |  6 +-
 .../sql/manage/RenameTopoGeometryColumn.sql.in     | 75 ++++++++++++++++++++++
 topology/test/regress/renametopogeometrycolumn.sql |  8 +++
 .../test/regress/renametopogeometrycolumn_expected |  3 +
 topology/test/tests.mk                             |  3 +-
 topology/topology.sql.in                           |  1 +
 8 files changed, 146 insertions(+), 4 deletions(-)
 create mode 100644 topology/sql/manage/RenameTopoGeometryColumn.sql.in
 create mode 100644 topology/test/regress/renametopogeometrycolumn.sql
 create mode 100644 topology/test/regress/renametopogeometrycolumn_expected
hooks/post-receive
