[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-328-gd5955a7e8
Tue Nov 8 14:03:56 PST 2022
the project "PostGIS".
       via  d5955a7e8ca2290f6567a426dd8a52b3b54340cc (commit)
      from  dbd2b5f819afd76322f0becd6e559d1ce4190f68 (commit)
revisions in full, below.
commit d5955a7e8ca2290f6567a426dd8a52b3b54340cc
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Nov 8 17:03:51 2022 -0500
    add some https to some urls and up the max version to PostgreSQL 16
diff --git a/doc/installation.xml b/doc/installation.xml
index 1624aee42..580993f94 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -33,8 +33,8 @@ in each individual database you want to use it in.
 		bleeding edge versions or you are a package maintainer.
 	  </para>
 	  <para>This section includes general compilation instructions, if you are compiling for Windows etc
-		or another OS, you may find additional more detailed help at <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiInstall">PostGIS User contributed compile guides</ulink> and <ulink url="http://trac.osgeo.org/postgis/wiki/DevWikiMain">PostGIS Dev Wiki</ulink>.</para>
-	  <para>Pre-Built Packages for various OS are listed in <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiPackages">PostGIS Pre-built Packages</ulink></para>
+		or another OS, you may find additional more detailed help at <ulink url="https://trac.osgeo.org/postgis/wiki/UsersWikiInstall">PostGIS User contributed compile guides</ulink> and <ulink url="http://trac.osgeo.org/postgis/wiki/DevWikiMain">PostGIS Dev Wiki</ulink>.</para>
+	  <para>Pre-Built Packages for various OS are listed in <ulink url="https://trac.osgeo.org/postgis/wiki/UsersWikiPackages">PostGIS Pre-built Packages</ulink></para>
 	  <para>If you are a windows user, you can get stable builds via Stackbuilder or <ulink url="https://postgis.net/windows_downloads">PostGIS Windows download site</ulink>
 	  We also have <ulink url="https://postgis.net/windows_downloads">very bleeding-edge windows experimental builds</ulink> that are built usually once or twice a week or whenever anything exciting happens.  You can
 	  use these to experiment with the in progress releases of PostGIS</para>
@@ -141,13 +141,13 @@ sh autogen.sh
 		  PostgreSQL &min_postgres_version; - &max_postgres_version;. A complete installation
 		  of PostgreSQL (including server headers) is required. PostgreSQL
 		  is available from
-		  <ulink url="http://www.postgresql.org">
+		  <ulink url="https://www.postgresql.org">
 		  </ulink>
 		</para>
 		<para>For a full PostgreSQL / PostGIS support matrix and PostGIS/GEOS support matrix refer to
-			<ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS">http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS</ulink>
+			<ulink url="https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS">https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS</ulink>
 		</para>
 	  </listitem>
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 70a4c2784..b85b443ea 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -14,7 +14,7 @@
 <!ENTITY last_proj_release_version "9.0.1">
 <!ENTITY last_geos_release_version "3.11.0">
 <!ENTITY min_postgres_version "12">
-<!ENTITY max_postgres_version "15">
+<!ENTITY max_postgres_version "16">
 <!ENTITY introduction SYSTEM "introduction.xml">
 <!ENTITY installation SYSTEM "installation.xml">
Summary of changes:
 doc/installation.xml | 8 ++++----
 doc/postgis.xml      | 2 +-
 2 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
