[postgis-tickets] [PostGIS] #5237: postgis_extensions_upgrade fails with ERROR: there is no unique or exclusion constraint matching the ON CONFLICT specification
PostGIS trac at osgeo.org
Wed Nov 9 03:17:37 PST 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.3.2
 Component:  postgis  |    Version:  3.3.x
Resolution:  wontfix  |   Keywords:
Comment (by strk):
 I suspect the primary key was removed when going from 1.x to 2.x which is
 when we restricted the allowed range of SRID values. In that occasion the
 postgis_restore.pl script made an effort of MOVING out-of-range SRID
 values within the valid range, but doing so might have introduced a
 conflict (same SRID / different other values) so in order not to still
 allow restore it dropped the constraint, loaded the data and then tried to
 re-add the constraint. Maybe in your case re-adding the constraint failed.
 Is your problem solved by now ? Were you able to re-add the primary key ?
 Did you find conflicts ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5237#comment:12>
