[postgis-tickets] [PostGIS] #5269: Berries and debbie failing on installing pgtopo_import and pgtopo_export, --prefix not respected (was: Berrie failing on installing shp2pgsql pgsql2shp)
PostGIS trac at osgeo.org
Wed Nov 9 04:55:21 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
 * summary:  Berrie failing on installing shp2pgsql pgsql2shp =>
Comment:
 I switched to using PGPATH no /bin.  Debbie has always been without bin
 and it worked before.  Why are they ignoring the --prefix now. I am also
 having same issue with winnie, except she doesn't error cause she has
 access to her /usr/share/bin folder. It's just the pgtopo_import and
 pgtopo_export going into the wrong folder not respecting her --prefix
 clause.  It respects it in 3.3 branch.
 The issue is not the shp2pgsql, but the pgtopo_import and pgtopo_export
 04:57:57 /bin/sh ../libtool --mode=install /usr/bin/install -c
 loader/pgtopo_import "/bin/pgtopo_import"
 04:57:57 libtool: install: /usr/bin/install -c loader/pgtopo_import
 /bin/pgtopo_import
 04:57:57 /usr/bin/install: cannot create regular file
 '/bin/pgtopo_import': Permission denied
 04:57:57 make[1]: *** [Makefile:181: install-importer] Error 1
 04:57:57 make[1]: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.4/topology'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5269#comment:4>
