[postgis-tickets] [PostGIS] #5269: Berries and debbie failing on installing pgtopo_import and pgtopo_export, --prefix not respected
PostGIS trac at osgeo.org
Wed Nov 9 07:56:28 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"e09c09524193c8b5fb1e5e00ac73865677adbb7c/git" e09c095/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e09c09524193c8b5fb1e5e00ac73865677adbb7c"
 Honour --prefix for setting bindir in topology/loader
 Should fix #5269
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5269#comment:7>
