[postgis-tickets] [PostGIS] #5287: PostGIS 2.5 error on upgrade view test
PostGIS trac at osgeo.org
Fri Nov 11 06:54:43 PST 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 2.5.9
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"47f59d9bcc174548a2802807337f042a9b076c65/git" 47f59d9/git]:
 {{{#!CommitTicketReference repository="git"
 revision="47f59d9bcc174548a2802807337f042a9b076c65"
 Do not create an ST_Union based view on upgrade (won't work)
 The code to support PG12 CREATE OR REPLACE AGGREGATE entered
 the code base in 3.0 so 2.5 does not support such upgrades.
 Closes #5287
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5287#comment:2>
