[postgis-tickets] [PostGIS] #5223: GEOS 3.10 doesn't regress cleanly with PostGIS 3.0
PostGIS trac at osgeo.org
Fri Nov 11 21:09:41 PST 2022
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.0.8
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"8958203b6fe5a3443db909d4a4d9fff7ef526219/git"
 8958203b/git]:
 {{{#!CommitTicketReference repository="git"
 revision="8958203b6fe5a3443db909d4a4d9fff7ef526219"
 Make tests regress on GEOS 3.11/3.10
 Remove some tests that can't be easily changed to work on all GEOS
 References #5223
 References #5220
 For PostGIS 3.0.8
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5223#comment:1>
