[postgis-tickets] [SCM] postgis.net branch website updated. 8357bf8fc03e7515cc1800b26d7b6c36d0822a63
Sat Nov 12 23:34:30 PST 2022
the project "postgis.net".
The branch, website has been updated
       via  8357bf8fc03e7515cc1800b26d7b6c36d0822a63 (commit)
      from  e0d1ad225e1e6fa7c44c5a0a25d75584f7150e38 (commit)
revisions in full, below.
commit 8357bf8fc03e7515cc1800b26d7b6c36d0822a63
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 13 02:33:11 2022 -0500
    Patch releases for 3.0, 3.1, 3.2, and 3.3
diff --git a/config/_default/params.toml b/config/_default/params.toml
index 73430fd..af9048d 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -141,20 +141,20 @@ dev_download = "/stuff"
     is_dev = true
   [postgis.releases.33]
     minor = "3.3"
-    dev = "3.3.2dev"
-    tag = "3.3.1"
+    dev = "3.3.3dev"
+    tag = "3.3.2"
   [postgis.releases.32]
     minor = "3.2"
-    dev = "3.2.4dev"
-    tag = "3.2.3"
+    dev = "3.2.5dev"
+    tag = "3.2.4"
   [postgis.releases.31]
     minor = "3.1"
-    dev = "3.1.8dev"
-    tag = "3.1.7"
+    dev = "3.1.9dev"
+    tag = "3.1.8"
   [postgis.releases.30]
     minor = "3.0"
-    dev = "3.0.8dev"
-    tag = "3.0.7"
+    dev = "3.0.9dev"
+    tag = "3.0.8"
   [postgis.releases.25]
     minor = "2.5"
     dev = "2.5.9"
diff --git a/content/post/2022/11-13_postgis-patches.md b/content/post/2022/11-13_postgis-patches.md
new file mode 100644
index 0000000..7c468a2
--- /dev/null
+++ b/content/post/2022/11-13_postgis-patches.md
@@ -0,0 +1,86 @@
+title: PostGIS 3.3.2, 3.2.4, 3.1.8, 3.0.8 Patch Releases
+layout: post
+category: news
+tags: [release,3.3,3.2,3.1,3.0]
+author: Regina Obe
+thumbnail:
+date: "2022-11-13"
+The PostGIS development team is pleased to provide
+security, bug fixes and performance enhancements
+3.3.2, 3.2.4, 3.1.8 and 3.0.8 for the 3.3, 3.2, 3.1, and 3.0 stable branches.
+<!--more-->
+**3.3.2**
+This release supports PostgreSQL 11 and higher, GEOS 3.6 and higher, and proj 5.2 and higher.
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.3.2.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.3.2/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.3.2.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.3.2.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-3.3/) [de]({{< loc "site.root">}}docs/manual-3.3/postgis-de.html) [ja]({{< loc "site.root">}}docs/manual-3.3/postgis-ja.html) [ko_KR]({{< loc "site.root">}}docs/manual-3.3/postgis-ko_KR.html)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.3.2.epub)
+**3.2.4**
+This release works for PostgreSQL 9.6-15.
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.2.4.tar.gz) [md5]({{< loc "postgis.dev_download">}}/postgis-3.2.4.tar.gz.md5)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.4/NEWS)
+* [PDF docs en]({{< loc "postgis.release_docs">}}/postgis-3.2.4.pdf)
+**3.1.8**
+This release supports PostgreSQL 9.6-14.
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.1.8.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.1.8/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.1.8.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.1.8.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-3.1)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.1.8.epub)
+**3.0.8**
+This release works with PostgreSQL 9.5-13  and GEOS >= 3.6
+Designed to take advantage of features in PostgreSQL 12+ and Proj 6+
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.8.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.8/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.8.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.8.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.8.epub)
+View all [closed tickets for  3.1.8, 3.0.8][1].
+After installing the binaries or after running pg_upgrade:
+For PostGIS 3.3, 3.2, 3.1, 3.0, 2.5
+do below which will upgrade all your postgis extensions.
+```postgres
+SELECT postgis_extensions_upgrade();
+For PostGIS 2.4 and below do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+-- if you use the other extensions packaged with postgis
+-- make sure to upgrade those as well
+```postgres
+ALTER EXTENSION postgis_sfcgal UPDATE;
+ALTER EXTENSION postgis_topology UPDATE;
+ALTER EXTENSION postgis_tiger_geocoder UPDATE;
+If you use legacy.sql or legacy_minimal.sql,
+make sure to rerun the version packaged with these releases.
+[1]: https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+3.1.8&milestone=PostGIS+3.0.8&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
Summary of changes:
 config/_default/params.toml                | 16 +++---
 content/post/2022/11-13_postgis-patches.md | 86 ++++++++++++++++++++++++++++++
 2 files changed, 94 insertions(+), 8 deletions(-)
 create mode 100644 content/post/2022/11-13_postgis-patches.md
hooks/post-receive
postgis.net
