[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 78084c6bd70c20ed5e1fe955237d1500e5956a8f
Sun Nov 13 12:26:19 PST 2022
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
       via  78084c6bd70c20ed5e1fe955237d1500e5956a8f (commit)
      from  d21308e5907d4bd76cd913614bd399ba7458a6f1 (commit)
revisions in full, below.
commit 78084c6bd70c20ed5e1fe955237d1500e5956a8f
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 13 15:26:13 2022 -0500
    First pass at a h3-pg build script
diff --git a/debian/bookkie.txt b/debian/bookkie.txt
new file mode 100644
index 0000000..01a1b20
--- /dev/null
+++ b/debian/bookkie.txt
@@ -0,0 +1,21 @@
+apt install default-jdk openssh-server #for jenkins to connect
+apt install autoconf libtool build-essential
+apt install libreadline8 libreadline-dev zlib1g-dev
+apt install libcunit1-dev libcunit1-doc libcunit1
+apt install docbook
+apt install libxml2-dev xsltproc docbook-xsl docbook-mathml gettext
+apt install libjson-c-dev
+apt install bison flex #needed to build postgis and postgresql
+apt install libiconv-hook1
+apt install libproj-dev
+apt install git
+apt install libgeos-dev libproj-dev
+apt install libgdal-dev
+apt install pkg-config
+apt install lz4 liblz4-dev #needed to build postgresql with lz4 support
+apt install postgresql postgresql-server-dev-all #installed postgresql-14
+apt install libpcre2-dev #for address standardizer
+apt install cmake #for geos
+apt install libsfcgal-dev #for postgis_sfcgal
+apt install libprotobuf-dev libprotobuf-c-dev libprotoc-dev protobuf-c-compiler #for mvt support
+apt install nano #general editing
\ No newline at end of file
diff --git a/debian/jenkins_setup.txt b/debian/jenkins_setup.txt
index f93dc9e..a0f9cec 100644
--- a/debian/jenkins_setup.txt
+++ b/debian/jenkins_setup.txt
@@ -107,8 +107,10 @@ which logbt
 logbt --version
-apt install latex-cjk-xcjk #for Korean and Chinese doc PDF translations
+#for Korean, Chinese, Japanese doc PDF translations
+#doesn't work yet
+apt install latex-cjk-xcjk
+apt install texlive-xetex texlive-fonts-extra texlive-fonts-recommended
 --if you need to update jenkins
 aptitude update
diff --git a/windows/mingw64/scripts/build_h3-pg.sh b/windows/mingw64/scripts/build_h3-pg.sh
index 0000000..4a427c1
--- /dev/null
+++ b/windows/mingw64/scripts/build_h3-pg.sh
@@ -0,0 +1,33 @@
+#!/bin/bash
+set -e
+#--passed in by Jenkins
+#export OS_BUILD=64
+#export GCC_TYPE=
+#export PG_VER=15
+#export LIBXML_VER=2.7.8
+#export PGPORT=5443
+#export H3PG_VER=
+export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
+export PGPATHEDB=${PGPATH}edb
+export PATH="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/bin:/include:/usr/local/bin:/cmake/bin"
+export PATH="${PATH}:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/zlib/rel-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/include:${PGPATH}/include:${PGPATH}/bin:/cmake/bin"
+export PGPORT=5452
+export PGUSER=postgres
+export SOURCES=/sources
+cd ${PROJECTS}
+cd h3-pg/h3-pg/
+git clean -fdx
+export INSTALL_DIR=/projects/h3-pg/builds/h3-pg_pg${PG_VER}w${OS_BUILD}-binaries-${H3PG_VER}
+cmake -B build -DCMAKE_BUILD_TYPE=Release
+make
+make install
+rm -rf ${INSTALL_DIR}
+mkdir -p ${INSTALL_DIR}/lib
+mkdir -p ${INSTALL_DIR}/docs
+mkdir -p ${INSTALL_DIR}/share/extension
+cp ${PGPATH}/lib/h3*.dll ${INSTALL_DIR}/lib
+cp ${PGPATH}/share/extension/h3*.control ${INSTALL_DIR}/share/extension
+cp ${PGPATH}/share/extension/h3*.sql ${INSTALL_DIR}/share/extension
+cp README.md ${INSTALL_DIR}
+cp LICENSE ${INSTALL_DIR}
+cp docs/*.md ${INSTALL_DIR}/docs/
Summary of changes:
 debian/bookkie.txt                     | 21 +++++++++++++++++++++
 debian/jenkins_setup.txt               |  6 ++++--
 windows/mingw64/scripts/build_h3-pg.sh | 33 +++++++++++++++++++++++++++++++++
 3 files changed, 58 insertions(+), 2 deletions(-)
 create mode 100644 debian/bookkie.txt
 create mode 100644 windows/mingw64/scripts/build_h3-pg.sh
hooks/post-receive
