[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 099b8c27ea5bd7a876fcb2483b9b3cc58ec93655
Sun Nov 13 19:18:06 PST 2022
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
       via  099b8c27ea5bd7a876fcb2483b9b3cc58ec93655 (commit)
      from  34047e6efc87d3a5086ac13c908bb5ef9a885379 (commit)
revisions in full, below.
commit 099b8c27ea5bd7a876fcb2483b9b3cc58ec93655
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 13 22:17:58 2022 -0500
    Revise script to work against main changes
diff --git a/windows/mingw64/scripts/build_h3-pg.sh b/windows/mingw64/scripts/build_h3-pg.sh
index 3de16c6..156ea9a 100644
--- a/windows/mingw64/scripts/build_h3-pg.sh
+++ b/windows/mingw64/scripts/build_h3-pg.sh
@@ -7,15 +7,27 @@ set -e
 #export LIBXML_VER=2.7.8
 #export PGPORT=5443
 #export H3PG_VER=
+if [ "$GCC_TYPE" == "tux" ]; then
+	export GCC_TYPE=
+fi
+export PROJECTS=/projects
 export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
 export PGPATHEDB=${PGPATH}edb
-export PATH="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/bin:/include:/usr/local/bin:/cmake/bin"
+export PGBIN=${PGPATH}/bin
+echo "PGBIN is $PGBIN"
+export PATH="/mingw/bin:/mingw/include:/mingw/lib:/c/Windows/system32:/bin:/include:/usr/local/bin"
 export PATH="${PATH}:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/zlib/rel-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/include:${PGPATH}/include:${PGPATH}/bin:/cmake/bin"
-export PGPORT=5452
+#export PGPORT=5452
 export PGUSER=postgres
 export SOURCES=/sources
 cd /projects
 cd h3-pg/h3-pg/
+make
+make install
+make installcheck
 #git clean -fdx
 export GIT_REVISION=`git status | head -1`
 export RELDIR=/projects/h3-pg/builds
@@ -24,39 +36,17 @@ export outdir="${RELDIR}/${RELVERDIR}"
 export package="${RELDIR}/${RELVERDIR}.zip"
 export INSTALL_DIR=${RELDIR}/${RELVERDIR}
 export verfile="${INSTALL_DIR}/h3-pg_version.txt"
-# h3 core library version to clone and statically link
-export LIBH3_VERSION=v4.0.1
-# directory that h3 core repository is cloned into
-export LIBH3_SOURCE=libh3-${LIBH3_VERSION}
-#build directory
-export LIBH3_BUILD=${LIBH3_SOURCE}/build
-git clone --branch ${LIBH3_VERSION} --depth 1 https://github.com/uber/h3 ${LIBH3_SOURCE}
-#build h3 library
-mkdir -p ${LIBH3_BUILD}
-cd ${LIBH3_BUILD} && cmake \
-		-G "Unix Makefiles" \
-		-DCMAKE_BUILD_TYPE=Release \
-		-DBUILD_TESTING=OFF \
-		-DENABLE_COVERAGE=OFF \
-		-DENABLE_DOCS=OFF \
-		-DENABLE_FORMAT=OFF \
-		-DENABLE_LINTING=OFF \
-#cmake -G "Unix Makefiles" --build ${LIBH3_BUILD} --target h3
-#cmake -G "Unix Makefiles" --build ${LIBH3_BUILD} --target binding-functions
-make
-cd /projects/h3-pg/h3-pg/
-make
-make install
 rm -rf ${INSTALL_DIR}
 mkdir -p ${INSTALL_DIR}/lib
 mkdir -p ${INSTALL_DIR}/docs
 mkdir -p ${INSTALL_DIR}/share/extension
 cp -r ${RELDIR}/packaging_notes/* ${INSTALL_DIR}/
-cp ${PGPATH}/lib/h3*.dll ${INSTALL_DIR}/lib
+cp build/h3/h3*.dll ${INSTALL_DIR}/lib
 cp ${PGPATH}/share/extension/h3*.control ${INSTALL_DIR}/share/extension
 cp ${PGPATH}/share/extension/h3*.sql ${INSTALL_DIR}/share/extension
 cp README.md ${INSTALL_DIR}
 cp LICENSE ${INSTALL_DIR}
 cp docs/*.md ${INSTALL_DIR}/docs/
Summary of changes:
 windows/mingw64/scripts/build_h3-pg.sh | 46 +++++++++++++---------------------
 1 file changed, 18 insertions(+), 28 deletions(-)
hooks/post-receive
