[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-339-g9c7af7f45
Wed Nov 16 03:23:32 PST 2022
the project "PostGIS".
       via  9c7af7f45ca45b4f3df3d8de83030f4166637d38 (commit)
      from  0c544a2df5b848bc0592d9a5e27487bdd25d82ba (commit)
revisions in full, below.
commit 9c7af7f45ca45b4f3df3d8de83030f4166637d38
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Nov 16 12:22:03 2022 +0100
    Reword paragraph about pgtopo_export, fixing a typo
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 3e865a854..beff2f074 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -4425,9 +4425,9 @@ The dump file format is a compressed tar archive of a
 at least a <filename>pgtopo_dump_version</filename> file with
 format version info. As of version <code>1</code> the directory
 contains tab-delimited CSV files with data of the topology
-primitive tables (node, edge_data, face, relation), of the
-topology and layer records associated with it, and optionall
-(if <code>--skip-layers</code> is not given) a custom-format
+primitive tables (node, edge_data, face, relation), the
+topology and layer records associated with it and
+(unless <code>--skip-layers</code> is given) a custom-format
 PostgreSQL dump of tables reported as being layers of the given
 topology.
         </para>
Summary of changes:
 doc/extras_topology.xml | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
