[postgis-tickets] [PostGIS] #5290: RHEL 8 Postgis 3.3.2 requires gdal35-libs >= 3.5.2
PostGIS trac at osgeo.org
Thu Nov 17 07:43:36 PST 2022
 Reporter:  marc3932  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.3.3
Component:  postgis   |    Version:  3.3.x
 Keywords:            |
 root at lnx8pg12 ~]# cat /etc/redhat-release
 Red Hat Enterprise Linux release 8.6 (Ootpa)
 [root at lnx8pg12 ~]# **yum install postgis33_13**
 Updating Subscription Management repositories.
 Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs) 17 kB/s | 2.4 kB
 00:00
 Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs) 19 kB/s | 2.8 kB
 00:00
 EPEL8 x86_64 18 kB/s | 2.7 kB 00:00
 **Error:
 Problem: package postgis33_13-3.3.2-1.rhel8.x86_64 requires gdal35-libs >=
 3.5.2, but none of the providers can be installed**
 package postgis33_13-3.3.2-1.rhel8.x86_64 requires libgdal.so.31()(64bit),
 cannot install the best candidate for the job
 nothing provides libqhull_r.so.7()(64bit) needed by
 gdal35-libs-3.5.2-3.rhel8.x86_64
 gdal35-libs-3.5.3-1.rhel8.x86_64
 (try to add '--skip-broken' to skip uninstallable packages or '--nobest'
 to use not only best candidate packages)
 [root at lnx8pg12 ~]# **yum install postgis33_12**
 Red Hat Enterprise Linux 8 for x86_64 - BaseOS (RPMs) 15 kB/s | 2.4 kB
 00:00
 Red Hat Enterprise Linux 8 for x86_64 - AppStream (RPMs) 18 kB/s | 2.8 kB
 00:00
 EPEL8 x86_64 22 kB/s | 2.7 kB 00:00
 **Error:
 Problem: package postgis33_12-3.3.2-1.rhel8.x86_64 requires gdal35-libs >=
 package postgis33_12-3.3.2-1.rhel8.x86_64 requires libgdal.so.31()(64bit),
 NOTE: RHEL 7 works fine to install Postgis 3.3.2 !!!
 NOTE: Issue was logged in RedHat Bugzilla and in Fedora Bodhi
 RedHat Bugzilla https://bugzilla.redhat.com/show_bug.cgi?id=2143703
 Fedora Bodhi https://github.com/fedora-infra/bodhi/issues/4832
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5290>
