[postgis-tickets] [PostGIS] #5288: ST_LineCrossingDirection defect on LINE MULTICROSS END SAME FIRST LEFT ?
PostGIS trac at osgeo.org
Sat Nov 19 14:19:36 PST 2022
  Reporter:  arthurbazin  |      Owner:  pramsey
      Type:  defect       |     Status:  new
  Priority:  medium       |  Milestone:
 Component:  postgis      |    Version:  3.2.x
Resolution:               |   Keywords:
Old description:
> With the ST_LineCrossingDirection, I have unexpected results.
> Using this request, I can simulate some crossing but the result is
> unexpected for
> the line 2 and 3 :
> SELECT
>   line_number,
>   ST_LineCrossingDirection(geom_a, geom_b) "a_/_b",
>   ST_LineCrossingDirection(geom_b, geom_a) "b_/_a",
>   geom_a,
>   geom_b
> FROM (
>   VALUES
>       'LINESTRING (1 0, 1 1, 2 2, 2 3)'::geometry,
>       'LINESTRING (2 0, 2 1, 1 2, 1 3)'::geometry,
>       1
>       'LINESTRING (1 0, 1 1, 2 2, 1 3, 1 4)'::geometry,
>       'LINESTRING (2 0, 2 1, 1 2, 2 3, 2 4)'::geometry,
>       2
>       'LINESTRING (1 0, 1 1, 2 2, 1 3, 2 4, 2 5)'::geometry,
>       'LINESTRING (2 0, 2 1, 1 2, 2 3, 1 4, 1 5)'::geometry,
>       3
>       'LINESTRING (1 0, 1 1, 2 2, 1 3, 2 4, 1 5, 1 6)'::geometry,
>       'LINESTRING (2 0, 2 1, 1 2, 2 3, 1 4, 2 5, 2 6)'::geometry,
>       4
> ) AS t1 ("geom_a", "geom_b", line_number)
> Result :
>  line_number | a_/_b | b_/_a | geom_a
> | geom_b                                         |
>            1 |    -1 |     1 | LINESTRING (1 0, 1 1, 2 2, 2 3)
> | LINESTRING (2 0, 2 1, 1 2, 1 3)                |
>            2 |    -3 |    -3 | LINESTRING (1 0, 1 1, 2 2, 1 3, 1 4)
> | LINESTRING (2 0, 2 1, 1 2, 2 3, 2 4)           |
>            3 |    -2 |     2 | LINESTRING (1 0, 1 1, 2 2, 1 3, 2 4, 2 5)
> | LINESTRING (2 0, 2 1, 1 2, 2 3, 1 4, 1 5)      |
>            4 |    -3 |    -3 | LINESTRING (1 0, 1 1, 2 2, 1 3, 2 4, 1 5,
> 1 6) | LINESTRING (2 0, 2 1, 1 2, 2 3, 1 4, 2 5, 2 6) |
> Will the column "b_/_a" be "3" instead of "-3" ?
> The A line comes from the left of B and the B line comes from the right
> of A
> Maybe I don't understand correctly this function but I can not explain
> how it works with this result.
> My version of PostGIS :
> POSTGIS="3.2.1 3.2.1" [EXTENSION] PGSQL="130" GEOS="3.10.2-CAPI-1.16.0"
> PROJ="7.2.1" GDAL="GDAL 3.4.2, released 2022/03/08 GDAL_DATA not found"
> LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
> (Internal)" RASTER
New description:
 unexpected for
 the line 2 and 4 :
 SELECT
   line_number,
   geom_a,
   geom_b
 FROM (
   VALUES
       1
       2
       3
       4
 Result :
 | geom_b                                         |
            4 |    -3 |    -3 | LINESTRING (1 0, 1 1, 2 2, 1 3, 2 4, 1 5, 1
 Will the column "b_/_a" be "3" instead of "-3" on lines 2 and 4 ?
 The A line comes from the left of B and the B line comes from the right of
 A
 Maybe I don't understand correctly this function but I can not explain how
 LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
 RASTER
Comment (by arthurbazin):
 Anyone can confirm that this is a bug and not my "misunderstanding" of
 this function that gives me this result ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5288#comment:1>
