[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-348-g56d525e77
Sun Nov 27 14:33:14 PST 2022
the project "PostGIS".
       via  56d525e779fa814893a2a3cf772c1980a270b0d9 (commit)
      from  c373d97ab0e8be110c25cda752f14bc254696f3f (commit)
revisions in full, below.
commit 56d525e779fa814893a2a3cf772c1980a270b0d9
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Nov 27 17:31:43 2022 -0500
    1. Put woodie to work
    2. Move doc test and pg12 testing to woodie
    3. Add pg14 testing to woodie
    4. Replace gitlab on ci chart with woodie
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index bdef7c560..831c42c1f 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -22,28 +22,9 @@ steps:
       - ./autogen.sh
     depends_on: [ clone ]
-  - name: build-12
-    image: *test-image
-    pull: never
-    commands:
-      - PGVER=12 sh ci/dronie/postgis_regress.sh
-    depends_on: [ autogen ]
   - name: build-13
     image: *test-image
     pull: never
     commands:
       - PGVER=13 sh ci/dronie/postgis_regress.sh
-  - name: build-docs
-    pull: never
-    commands:
-      - mkdir -p build-docs && cd build-docs
-      - ../configure
-      - make docs
-      - make -C doc check
-      - make docs-localized
-      - make -C doc/ check-localized
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
new file mode 100644
index 000000000..384559f61
--- /dev/null
+++ b/.woodpecker/docs.yml
@@ -0,0 +1,11 @@
+pipeline:
+  build:
+    image: docker.osgeo.org/postgis/build-test:trisquel3
+    commands:
+      - ./autogen.sh
+      - mkdir -p build-docs && cd build-docs
+      - ../configure
+      - make docs
+      - make -C doc check
+      - make docs-localized
+      - make -C doc/ check-localized
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 000000000..5274868b5
--- /dev/null
+++ b/.woodpecker/regress.yml
@@ -0,0 +1,12 @@
+matrix:
+  PG_VERSION:
+    - 14
+    - 12
+pipeline:
+  build:
+    group: build
+    commands:
+      - sh autogen.sh
+      - PGVER=${PG_VERSION} sh ci/dronie/postgis_regress.sh
diff --git a/README.md b/README.md
index 1492fcfa2..edc857aba 100644
--- a/README.md
+++ b/README.md
@@ -8,8 +8,8 @@
 |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run%2Flabel%3Dbessie)](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/) |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run%2Flabel%3Dbessie32)](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/) |  [![Build Status](https://api.cirrus-ci.com/github/postgis/postgis.svg?branch=master)](http://cirrus-ci.com/github/postgis/postgis) |
 | **Berrie** | **Berrie64** |
 |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:${params.reference=refs/heads/master})](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/) |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:${params.reference=refs/heads/master})](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/) | ||
-| **GitHub** | **GitLab** |
-| [![CI](https://github.com/postgis/postgis/workflows/CI/badge.svg?branch=master)](https://github.com/postgis/postgis/actions?query=branch%3Amaster) | [![Gitlab-CI](https://gitlab.com/postgis/postgis/badges/master/pipeline.svg)](https://gitlab.com/postgis/postgis/commits/master) ||
+| **GitHub** | **Woodie** |
+| [![CI](https://github.com/postgis/postgis/workflows/CI/badge.svg?branch=master)](https://github.com/postgis/postgis/actions?query=branch%3Amaster) | [![Woodie](https://woodie.osgeo.org/api/badges/postgis/postgis/status.svg?branch=master)](https://woodie.osgeo.org/postgis/postgis/branches/master) ||
 This file is here to play nicely with modern code repository facilities.
 Actual readme is [here](README.postgis).
Summary of changes:
 .drone-1.0.yml          | 19 -------------------
 .woodpecker/docs.yml    | 11 +++++++++++
 .woodpecker/regress.yml | 12 ++++++++++++
 README.md               |  4 ++--
 4 files changed, 25 insertions(+), 21 deletions(-)
 create mode 100644 .woodpecker/docs.yml
 create mode 100644 .woodpecker/regress.yml
hooks/post-receive
