[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-151-g138d591df
Sat Oct 1 18:25:29 PDT 2022
the project "PostGIS".
       via  138d591dff88034d803abe8f30e6e495783bf17b (commit)
       via  4e80d8d335317578df57431f9070595d935fda56 (commit)
      from  94a14f36210081882d13dacf3c809992b2a58004 (commit)
revisions in full, below.
commit 138d591dff88034d803abe8f30e6e495783bf17b
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Oct 1 21:24:24 2022 -0400
    Fix postgis_extensions_upgrade for same version to same version.
    Tests still needed
    References #5253 for PostGIS 3.4.0dev
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 798e26eea..2e50a77f5 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3051,7 +3051,7 @@ BEGIN
 			END IF; --}
 		ELSE -- The code is already packaged, upgrade it --}{
 			sql = format(
-				'ALTER EXTENSION %1$I UPDATE TO ANY;',
+				'ALTER EXTENSION %1$I UPDATE TO "ANY";'
 				'ALTER EXTENSION %1$I UPDATE TO %2$I',
 				rec.name, target_version
commit 4e80d8d335317578df57431f9070595d935fda56
Date:   Sat Oct 1 21:22:20 2022 -0400
    winnie fialing on ANY tests.
    Closes #5252
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index c546eab84..68a2ea31d 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -252,22 +252,21 @@ export UPGRADEABLE_VERSIONS=$value
 #echo "Versions are:  $UPGRADEABLE_VERSIONS"
 export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
 for EXTNAME in postgis postgis_raster postgis_topology postgis_sfcgal postgis_tiger_geocoder address_standardizer; do
-	cp extensions/$EXTNAME/sql/*  ${PGPATHEDB}/share/extension
+	cp extensions/$EXTNAME/sql/*  ${RELDIR}/${RELVERDIR}/share/extension
+	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/$EXTNAME--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/$EXTNAME--${POSTGIS_MICRO_VER}next--${POSTGIS_MICRO_VER}.sql
-	cp extensions/$EXTNAME/sql/$EXTNAME--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/$EXTNAME--${POSTGIS_MICRO_VER}--${POSTGIS_MICRO_VER}next.sql
 	if test "$EXTNAME" = "address_standardizer"; then #repeat for address_standardizer_data_us
-		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--${POSTGIS_MINOR_MAX_VER}--${POSTGIS_MICRO_VER}.sql
-		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--${POSTGIS_MICRO_VER}next--${POSTGIS_MICRO_VER}.sql
+		cp extensions/$EXTNAME/sql/${EXTNAME}_data_us--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
+		cp extensions//$EXTNAME/sql/${EXTNAME}_data_us--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
 	fi
 	for OLD_VERSION in $UPGRADEABLE_VERSIONS; do \
 		if [ "$OLD_VERSION" > "2.5" ] || [ "$OLD_VERSION" in $WIN_RELEASED_VERSIONS ]; then
-			cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/$EXTNAME--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+			cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${RELDIR}/${RELVERDIR}/share/extension/$EXTNAME--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
-				cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
+				cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql ${RELDIR}/${RELVERDIR}/share/extension/${EXTNAME}_data_us--$OLD_VERSION--${POSTGIS_MINOR_MAX_VER}.sql; \
 			fi
 		fi
 	done
@@ -283,7 +282,7 @@ cp -r extensions/*/*.dll ${RELDIR}/${RELVERDIR}/lib #only address_standardizer i
 cp -r ${RELDIR}/packaging_notes/* ${RELDIR}/${RELVERDIR}/
-echo "GEOS VERSION: ${GEOS_VER} https://trac.osgeo.org/geos" >> $verfile
+echo "GEOS VERSION: ${GEOS_VER} https://github.com/libgeos/geos" >> $verfile
 echo "GDAL VERSION: ${GDAL_VER} https://gdal.org/download.html#current-releases" >> $verfile
 echo "PROJ VERSION: ${PROJ_VER} https://proj.org/download.html#current-release" >> $verfile
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 04ff56919..1dbc53d5b 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -202,6 +202,7 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
 export POSTGIS_MINOR_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
 export POSTGIS_MINOR_MAX_VER="ANY"
+export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
 #export UPGRADE_VER_FILE="extensions/upgradeable_versions.mk"
 value=$(<extensions/upgradeable_versions.mk)
@@ -213,16 +214,12 @@ export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.
+	cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql  ${PGPATHEDB}/share/extension/$EXTNAME--$POSTGIS_MICRO_VER--${POSTGIS_MINOR_MAX_VER}.sql;
-		cp extensions/postgis/sql/postgis--ANY--${POSTGIS_MICRO_VER}.sql  ${PGPATHEDB}/share/extension
+		cp extensions/$EXTNAME/sql/${EXTNAME}--TEMPLATED--TO--ANY.sql ${PGPATHEDB}/share/extension/${EXTNAME}_data_us--$POSTGIS_MICRO_VER--ANY.sql;
 	fi
@@ -242,21 +239,22 @@ done
  make check RUNTESTFLAGS="--extension -v"
+## TODO: Put back after folder into main check setup #5254
  ##test address standardizer
- cd ${POSTGIS_SRC}
- cd extensions/address_standardizer
- make installcheck
+ #cd ${POSTGIS_SRC}
+ #cd extensions/address_standardizer
+ #make installcheck
  ##test tiger geocoder
- cd ${POSTGIS_SRC}
- cd extensions/postgis_tiger_geocoder
- make installcheck
+ #cd extensions/postgis_tiger_geocoder
  if [ "$?" != "0" ]; then
   exit $?
  fi
 fi
-if [ "$DUMP_RESTORE" = "1" ]; then
+if [ "$DUMP_RESTORE" == "1" ]; then
  echo "Dum restore test"
  make install
  make check RUNTESTFLAGS="-v --dumprestore"
Summary of changes:
 ci/winnie/package_postgis.sh | 17 ++++++++---------
 ci/winnie/regress_postgis.sh | 26 ++++++++++++--------------
 postgis/postgis.sql.in       |  2 +-
 3 files changed, 21 insertions(+), 24 deletions(-)
hooks/post-receive
