[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-153-g23c99aa45
Sat Oct 1 19:04:48 PDT 2022
the project "PostGIS".
       via  23c99aa4584d6df2b6b6873eb454405688d5579c (commit)
       via  2e1ad3606f427e149a4dd077507af00448968fbf (commit)
      from  138d591dff88034d803abe8f30e6e495783bf17b (commit)
revisions in full, below.
commit 23c99aa4584d6df2b6b6873eb454405688d5579c
Author: Regina Obe <regina at arrival3d.com>
Date:   Sat Oct 1 01:53:01 2022 +0000
    Translated using Weblate (Romanian)
    Currently translated at 23.4% (22 of 94 strings)
    Translation: postgis/administration.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ro/
diff --git a/doc/po/ro/administration.xml.po b/doc/po/ro/administration.xml.po
index 32a154577..880ad3650 100644
--- a/doc/po/ro/administration.xml.po
+++ b/doc/po/ro/administration.xml.po
@@ -1,12 +1,13 @@
 # SOME DESCRIPTIVE TITLE.
 # Florentin Drogeanu <drogeanu.florentin at gmail.com>, 2022.
+# Regina Obe <regina at arrival3d.com>, 2022.
 msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-07-13 19:13+0000\n"
-"PO-Revision-Date: 2022-08-16 23:55+0000\n"
-"Last-Translator: Florentin Drogeanu <drogeanu.florentin at gmail.com>\n"
+"PO-Revision-Date: 2022-10-02 02:04+0000\n"
+"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
 "Language-Team: Romanian <https://weblate.osgeo.org/projects/postgis/"
 "administrationxml/ro/>\n"
 "Language: ro\n"
@@ -15,7 +16,7 @@ msgstr ""
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=3; plural=n==1 ? 0 : (n==0 || (n%100 > 0 && n%100 < "
 "20)) ? 1 : 2;\n"
-"X-Generator: Weblate 4.13.1\n"
+"X-Generator: Weblate 4.14.1\n"
 #. Tag: title
 #: administration.xml:3
@@ -118,7 +119,7 @@ msgstr "POSTGIS_GDAL_ENABLED_DRIVERS=\"GTiff PNG JPEG GIF XYZ\""
 #. Tag: para
 #: administration.xml:27
-#, fuzzy, no-c-format
+#, no-c-format
 msgid "If you are on windows, do not quote the driver list"
 msgstr "Dacă sunteți pe Windows, nu citați lista de drivere"
commit 2e1ad3606f427e149a4dd077507af00448968fbf
Date:   Sat Oct 1 01:58:26 2022 +0000
    Translated using Weblate (Korean)
    Currently translated at 74.1% (184 of 248 strings)
    Translation: postgis/installation.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/installationxml/ko/
diff --git a/doc/po/ko_KR/installation.xml.po b/doc/po/ko_KR/installation.xml.po
index 9c91187ab..cb486272a 100644
--- a/doc/po/ko_KR/installation.xml.po
+++ b/doc/po/ko_KR/installation.xml.po
@@ -10,15 +10,16 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "POT-Creation-Date: 2022-08-08 04:50+0000\n"
-"PO-Revision-Date: 2018-07-22 02:56+0000\n"
-"Last-Translator: georgersilva <georger.silva at gmail.com>\n"
-"Language-Team: Korean (Korea) (http://www.transifex.com/postgis/postgis/"
-"language/ko_KR/)\n"
+"Language-Team: Korean <https://weblate.osgeo.org/projects/postgis/"
+"installationxml/ko/>\n"
 "Language: ko_KR\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
 #. Tag: title
 #: installation.xml:3
@@ -42,11 +43,11 @@ msgstr "짧은 설명"
 #: installation.xml:11
 #, no-c-format
 msgid "To compile assuming you have all the dependencies in your search path:"
-msgstr "사용자의 검색 경로에 모든 의존성이 설정되어 있을 깨 컴파일하려면:"
+msgstr "사용자의 검색 경로에 모든 의존성이 설정되어 있을 때 컴파일하려면:"
 #. Tag: programlisting
 #: installation.xml:12
+#, no-c-format
 msgid ""
 "tar -xvfz postgis-&last_release_version;.tar.gz\n"
 "cd postgis-&last_release_version;\n"
@@ -54,7 +55,7 @@ msgid ""
 "make\n"
 "make install"
 msgstr ""
-"tar xvfz postgis-&last_release_version;.tar.gz\n"
+"tar -xvfz postgis-&last_release_version;.tar.gz\n"
 "./configure\n"
 "make\n"
@@ -62,20 +63,21 @@ msgstr ""
 #. Tag: para
 #: installation.xml:13
+#, no-c-format
 msgid ""
 "Once PostGIS is installed, it needs to be enabled (<xref "
 "linkend=\"create_spatial_db\"/>) or upgraded (<xref linkend=\"upgrading\"/>) "
 "in each individual database you want to use it in."
 msgstr ""
-"PostGIS가 설치되면, PostGIS를 사용하고자 하는 모든 데이터베이스 각각에서 활성"
-"화해야 합니다."
+"PostGIS가 설치되면, PostGIS를 사용하고자 하는 모든 데이터베이스 각각에서 "
+"활성화하거나 (<xref linkend=\"create_spatial_db\"/>)업그레이드(<xref linkend="
+"\"upgrading\"/>)해야 합니다."
 #. Tag: title
 #: installation.xml:23
+#, no-c-format
 msgid "Compiling and Install from Source"
-msgstr "소스를 컴파일하고 설치하기: 상세 설명"
+msgstr "소스를 컴파일하고 설치하기"
 #. Tag: para
 #: installation.xml:26
@@ -85,8 +87,8 @@ msgid ""
 "many cases compilation is only necessary if you want the most bleeding edge "
 "versions or you are a package maintainer."
 msgstr ""
-"현재 많은 OS 시스템들이 PostgreSQL/PostGIS용 사전 구축된 패키지를 포함하고 있"
-"습니다. 많은 경우, 최첨단 버전이 필요하거나 패키지 관리자인 경우가 아니라면 "
+"현재 많은 OS 시스템들이 PostgreSQL/PostGIS용 사전 구축된 패키지를 포함하고 "
+"있습니다. 많은 경우, 최신 버전이 필요하거나 패키지 관리자인 경우가 아니라면 "
 "컴파일할 필요가 없습니다."
 #. Tag: para
Summary of changes:
 doc/po/ko_KR/installation.xml.po | 30 ++++++++++++++++--------------
 doc/po/ro/administration.xml.po  |  9 +++++----
 2 files changed, 21 insertions(+), 18 deletions(-)
hooks/post-receive
