[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-161-gb9439d2d0
Sun Oct 2 12:12:20 PDT 2022
the project "PostGIS".
       via  b9439d2d0d7cabfad1fbed3c71c720be13b89133 (commit)
      from  de60ad171eee64e5516a474b56e528f6ef684341 (commit)
revisions in full, below.
commit b9439d2d0d7cabfad1fbed3c71c720be13b89133
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Oct 2 15:12:12 2022 -0400
    Fix current / current test.  References #5253
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 0d52bc51a..458822d8f 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -228,18 +228,16 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
   CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
   # Test current version to current version extension upgrade
-  do #{
-    UPGRADE_PATH="${CURRENTVERSION}--:auto!"
-    test_label="${EXT} extension-based upgrade ${UPGRADE_PATH}"
-    echo "Testing ${test_label}"
-    RUNTESTFLAGS="--extension -v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
-    make -C ${REGDIR} check && {
-      echo "PASS: ${test_label}"
-      echo "FAIL: ${test_label}"
-      failed
-  done #}
+  UPGRADE_PATH="${CURRENTVERSION}--:auto!"
+  test_label="${EXT} extension-based upgrade ${UPGRADE_PATH}"
+  echo "Testing ${test_label}"
+  RUNTESTFLAGS="--extension -v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
+  make -C ${REGDIR} check && {
+    echo "PASS: ${test_label}"
+    echo "FAIL: ${test_label}"
+    failed
   # Check unpackaged->unpackaged upgrades
   if test "${to_version}" = "${CURRENTVERSION}"; then
Summary of changes:
 utils/check_all_upgrades.sh | 22 ++++++++++------------
 1 file changed, 10 insertions(+), 12 deletions(-)
hooks/post-receive
