[postgis-tickets] [PostGIS] #5253: postgis_extensions_upgrade is broken for upgrade from 3.4.0dev to 3.4.0dev
PostGIS trac at osgeo.org
Mon Oct 3 05:27:13 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Comment (by strk):
 Replying to [comment:8 Regina Obe <lr@…>]:
 > In [changeset:"b9439d2d0d7cabfad1fbed3c71c720be13b89133/git"
 b9439d2/git]:
 > {{{#!CommitTicketReference repository="git"
 revision="b9439d2d0d7cabfad1fbed3c71c720be13b89133"
 > Fix current / current test.  References #5253
 I think this commit should not be needed, could you please file a separate
 ticket for the issue you saw of CI not testing what it should test ?
 The check_all_upgrades.sh script takes the target as a parameter, so
 whether or not script-based is used depends on the parameter (`:auto!`
 uses the function while `:auto` does not)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5253#comment:10>
