[postgis-tickets] [PostGIS] #5257: PG16 doesn't load against 3.4.0 (master) - MemoryContextContains removed in PG16
PostGIS trac at osgeo.org
Mon Oct 10 20:28:42 PDT 2022
PG16
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:  PG16
Changes (by Regina Obe <lr@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"b49f566adc39eec98f43a80e5cfe6f51c795169c/git" b49f566/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b49f566adc39eec98f43a80e5cfe6f51c795169c"
 Remove MemoryContextContains use for PG16
 Closes #5257 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5257#comment:3>
