[postgis-tickets] [PostGIS] #5260: geos310 failure against GEOS main (3.12dev)
PostGIS trac at osgeo.org
Wed Oct 19 13:44:30 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.3.2
Component:  postgis  |    Version:  master
 Keywords:           |
 Both winnie and debbie are showing this regress failure when testing
 against  GEOS main
 Debbie
 16:08:25   GEOS: 3.12.0dev-CAPI-1.18.0
 16:08:25   PROJ: 7.2.1
 16:08:25   SFCGAL: 1.3.8
 16:08:25   GDAL: GDAL 3.4.3, released 2022/04/22
 winnie
 PostgreSQL 15.0, compiled by Visual C++ build 1914, 64-bit
   Postgis 3.4.0dev - (3.3.0rc2-223-g46005ff37) - 2022-10-19 00:18:42
   scripts 3.4.0dev 3.3.0rc2-223-g46005ff37
   raster scripts 3.4.0dev 3.3.0rc2-223-g46005ff37
   PROJ: 7.2.1
   SFCGAL: 1.4.1
  ./regress/core/geos310 .. failed (diff expected obtained:
 /projects/postgis/tmp/3.4.0dev_pg15_geos3.12_gdal3.4.3w64/test_117_diff)
 --- ./regress/core/geos310_expected     2022-08-27 01:02:58.508984000
 -0400
 +++ /projects/postgis/tmp/3.4.0dev_pg15_geos3.12_gdal3.4.3w64/test_117_out
 2022-10-18 20:40:43.779910600 -0400
 @@ -1 +1 @@
 -#168|3|MULTIPOLYGON ZM (((4275341.969778511 259186.96699306098
 1323.762958283311 -1.797693134862316e+308,4275341.969778511
 259186.96699306098 1323.762958283311
 -1.797693134862316e+308,4275341.969778511 259186.96699306098
 1323.762958283311 -1.797693134862316e+308)))|Too few points in geometry
 component[4275341.96977851 259186.966993061 1323.76295828331]
 +#168|3|MULTIPOLYGON ZM (((4275341.969778511 259186.96699306098
 component[4275341.96977851 259186.966993061]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5260>
