[postgis-tickets] [PostGIS] #5260: geos310 failure against GEOS main (3.12dev)
PostGIS trac at osgeo.org
Fri Oct 21 07:29:20 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.2
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 Forgot to mention the test failing is:
 SELECT '#168', ST_NPoints(g), ST_AsText(g), ST_isValidReason(g)
 FROM ( VALUES
 ('01060000C00100000001030000C00100000003000000E3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFFE3D9107E234F5041A3DB66BC97A30F4122ACEF440DAF9440FFFFFFFFFFFFEFFF'::geometry)
 ) AS v(g);
 I'm guessing might be caused by this commit -
 https://github.com/libgeos/geos/commit/32348a68c5212c89cfefab46891d2b3aada4ab40
 which happened around same time tests started failing.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5260#comment:2>
