[postgis-tickets] [PostGIS] #5263: Cirrus CI Freebsd failing on raster script builds again (FreeBSD)
PostGIS trac at osgeo.org
Fri Oct 21 09:43:16 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"510d8d7d5d65d2679b1591abc8dbcb872110cd5a/git" 510d8d7/git]:
 {{{#!CommitTicketReference repository="git"
 revision="510d8d7d5d65d2679b1591abc8dbcb872110cd5a"
 [cirrus-ci] Stop using parallel make
 References #5263
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5263#comment:1>
