[postgis-tickets] [PostGIS] #5270: bessie regress failure on computed columns
PostGIS trac at osgeo.org
Thu Oct 27 07:01:53 PDT 2022
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 3.4.0
Component:  postgis  |    Version:  3.3.x
 Keywords:           |
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/4052/consoleFull
 22:13:04 PostgreSQL 13.7 on amd64-portbld-freebsd12.3, compiled by FreeBSD
 clang version 10.0.1 (git at github.com:llvm/llvm-project.git
 llvmorg-10.0.1-0-gef32c611aa2), 64-bit
 22:13:04   Postgis 3.4.0dev - (0415ccb) - 2022-10-27 02:09:34
 22:13:04   scripts 3.4.0dev 0415ccb
 22:13:04   raster scripts 3.4.0dev 0415ccb
 22:13:04   GEOS: 3.10.3-CAPI-1.16.1
 22:13:04   PROJ: 8.2.1
 22:13:04   SFCGAL: 1.4.1
 22:13:04   GDAL: GDAL 3.5.0, released 2022/05/10
 22:14:32  ./regress/core/computed_columns .. failed (diff expected
 obtained:
 /home/jenkins/tmp/pgis_reg_0415ccb6da8a8b313302c874cff2359e596fd982/test_113_diff)
 22:14:36
 22:14:36 --- ./regress/core/computed_columns_expected   2022-10-26
 22:09:21.520763000 -0400
 22:14:36 +++
 /home/jenkins/tmp/pgis_reg_0415ccb6da8a8b313302c874cff2359e596fd982/test_113_out
 2022-10-26 22:14:36.022438000 -0400
 22:14:36 @@ -1,3 +1,3 @@
 22:14:36 -t
 22:14:36 +f
 22:14:36  t
 22:14:36  NOTICE:  drop cascades to 4 other objects
 22:14:36
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5270>
