[postgis-tickets] [PostGIS] #5241: ST_SnapToGrid crashes on multipolygon with an empty polygon
PostGIS trac at osgeo.org
Thu Oct 27 08:20:02 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.0.8
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Changes (by robe):
 * owner:  pramsey => robe
Old description:
> SELECT ST_SnapToGrid(foo1.the_geom, 20.1, 20.1, 20.1, 20.1)  As result
>                                                         FROM (
>                 (SELECT ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2
> 4, 7 7, 9 9)), EMPTY)', 4326) As the_geom ) ) As foo1 LIMIT 10;
> I tested this on 3.2.4dev, but assume it crashes on older
New description:
                                                         FROM (
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5241#comment:1>
