[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-289-g1f3fc078f
Thu Oct 27 10:06:20 PDT 2022
the project "PostGIS".
       via  1f3fc078faa66ed6596a5715883fe77764ae071f (commit)
      from  030dfee6d13c43d00781d60bdba6d294517b9634 (commit)
revisions in full, below.
commit 1f3fc078faa66ed6596a5715883fe77764ae071f
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 29 11:13:33 2022 +0200
    Drop security definers and add check to verify it
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index dc5e93fd9..31e7202ae 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1134,23 +1134,26 @@ CREATE OR REPLACE FUNCTION ST_MakeBox2d(geom1 geometry, geom2 geometry)
 -- Availability: 2.3.0
+-- Changed: 3.4.0 drop security definer
 CREATE OR REPLACE FUNCTION ST_EstimatedExtent(text,text,text,boolean) RETURNS box2d AS
 	'MODULE_PATHNAME', 'gserialized_estimated_extent'
-	LANGUAGE 'c' STABLE STRICT SECURITY DEFINER;
+	LANGUAGE 'c' STABLE STRICT;
 -- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION ST_EstimatedExtent(text,text,text) RETURNS box2d AS
 -- ST_ESTIMATED_EXTENT( <table name>, <column name> )
 CREATE OR REPLACE FUNCTION ST_EstimatedExtent(text,text) RETURNS box2d AS
 -- FIND_EXTENT( <schema name>, <table name>, <column name> )
diff --git a/regress/core/regress.sql b/regress/core/regress.sql
index 17982981e..62de3563d 100644
--- a/regress/core/regress.sql
+++ b/regress/core/regress.sql
@@ -341,7 +341,7 @@ ORDER BY 2;
 -- Make sure all postgis functions are owned by the
 -- same role as postgis_lib_version
-SELECT DISTINCT 'unexpected ownership', proname || ':' || proowner::regrole
+SELECT DISTINCT 'unexpected ownership', oid::regprocedure,  proowner::regrole
 FROM pg_proc
 WHERE (
 	probin like '%postgis%'
@@ -359,6 +359,19 @@ AND proowner !=
 ORDER BY 2;
+-- Make sure all postgis functions are SECURITY INVOKER
+SELECT DISTINCT 'unexpected security definer', oid::regprocedure, prosecdef
+FROM pg_proc
+WHERE (
+	probin like '%postgis%'
+  OR (
+		probin is null and
+		oid::regprocedure::text like 'st\_%' or
+		oid::regprocedure::text like 'postgis_%'
+AND prosecdef
+ORDER BY oid;
 SELECT 'UNEXPECTED', postgis_full_version()
 	WHERE postgis_full_version() LIKE '%UNPACKAGED%'
Summary of changes:
 postgis/postgis.sql.in   |  9 ++++++---
 regress/core/regress.sql | 15 ++++++++++++++-
 2 files changed, 20 insertions(+), 4 deletions(-)
hooks/post-receive
