[postgis-tickets] [PostGIS] #5267: [Enhacement] Extrapolate Linestring rate and distance support
PostGIS trac at osgeo.org
Thu Oct 27 10:52:27 PDT 2022
  Reporter:  latot        |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.4.0
 Component:  postgis      |    Version:  3.3.x
Resolution:               |   Keywords:
Comment (by mdavis):
 Replying to [comment:3 latot]:
 > With the actual params, ST_LineSubstring can pick the rate, the constant
 is useful too, but I don't know if put that inside the function too.
 > The constant part is pretty useful too, specially if you need extend a
 linestring over some extent, will small linestrings the rate only does the
 calc more complex, while a constant do it simpler.
 Are you suggesting adding an option to specify that the `start` and `end`
 parameters are absolute lengths, rather than a fraction of the line
 length?
 This could be done with an option flag, or with a new function (say
 `ST_LineSubstringLen`).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5267#comment:6>
