[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.7-7-g6c1718af3
Thu Oct 27 17:29:04 PDT 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  6c1718af32c2abac17b6402eab383fe0832aac06 (commit)
      from  dc920869de1575f4799e0b9e484ae7a193188459 (commit)
revisions in full, below.
commit 6c1718af32c2abac17b6402eab383fe0832aac06
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Oct 28 00:37:19 2022 +0200
    Check ownership of functions match that of extension upon packaging
    References #4648 in 3.0 branch (3.0.8dev)
diff --git a/NEWS b/NEWS
index c3c418d12..f394d180c 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ YYYY/MM/DD
 * Bug Fixes*
   - Add schema qual to upgrade util
   - #5240, ST_DumpPoints crash with empty polygon (Regina Obe)
+  - #4648, Check function ownership at extension packaging time (Sandro Santilli)
 PostGIS 3.0.7
 2022/08/18
diff --git a/utils/create_unpackaged.pl b/utils/create_unpackaged.pl
index 80c32b130..f80739e4d 100755
--- a/utils/create_unpackaged.pl
+++ b/utils/create_unpackaged.pl
@@ -24,6 +24,7 @@ die "Usage: perl $0 <extname> [<sql>]\n"
 unless @ARGV;
 my $extname = shift(@ARGV);
+my $scriptname = @ARGV ? $ARGV[0] : '-';
 # drops are in the following order:
 #	1. Indexing system stuff
@@ -141,22 +142,62 @@ while( my $line = <>)
 sub add_if_not_exists
   my $obj = shift;
-  print <<"EOF"
-DO \$\$
-BEGIN
-	-- TODO: check if ownership of the object
-	--       matches ownership of the extension
-	--       the object to the extension
+	# Prevent troubles by refusing to accept single quotes
+	# in objects
+	die "Invalid characters in object definition: $obj" if $obj =~ /'/;
+	$obj =~ m/([^ ]*) (.*)/;
+	my $type = $1;
+	my $sig = $2;
+  print "SELECT _postgis_package_object('$type', '$sig');\n";
+my $time = POSIX::strftime("%F %T", gmtime(defined($ENV{SOURCE_DATE_EPOCH}) ? $ENV{SOURCE_DATE_EPOCH} : time));
+print <<"EOF";
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- Generated on: $time
+--           by: $0
+--          for: $extname
+--         from: $scriptname
+-- Do not edit manually, your changes will be lost.
+-- complain if script is sourced in psql
+\\echo Use "CREATE EXTENSION ${extname} to load this file. \\quit
+CREATE FUNCTION _postgis_package_object(type text, sig text)
+RETURNS VOID
+AS \$\$
+DECLARE
+	sql text;
+	proc regproc;
+	obj text := format('%s %s', type, sig);
+BEGIN
-	ALTER EXTENSION $extname ADD $obj;
-	RAISE NOTICE 'newly registered $obj';
+	sql := format('ALTER EXTENSION ${extname} ADD %s', obj);
+	EXECUTE sql;
+	RAISE NOTICE 'newly registered %', obj;
 EXCEPTION
 WHEN object_not_in_prerequisite_state THEN
-  IF SQLERRM ~ '\\m$extname\\M'
+  IF SQLERRM ~ '\\m${extname}\\M'
   THEN
-    RAISE NOTICE 'already registered $obj';
+    RAISE NOTICE '% already registered', obj;
   ELSE
     RAISE EXCEPTION '%', SQLERRM;
   END IF;
@@ -166,39 +207,12 @@ WHEN
 	undefined_object
 	-- TODO: handle more exceptions ?
 THEN
-	RAISE NOTICE 'Object $obj does not exist yet';
+	RAISE NOTICE '% % does not exist yet', type, sig;
 WHEN OTHERS THEN
-	RAISE EXCEPTION 'Trying to add $obj to $extname, got % (%)', SQLERRM, SQLSTATE;
+	RAISE EXCEPTION 'Trying to add % to ${extname}, got % (%)', obj, SQLERRM, SQLSTATE;
 END;
 \$\$ LANGUAGE 'plpgsql';
 EOF
-my $time = POSIX::strftime("%F %T", gmtime(defined($ENV{SOURCE_DATE_EPOCH}) ? $ENV{SOURCE_DATE_EPOCH} : time));
-print "-- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --\n";
-print "--\n";
-print "-- PostGIS - Spatial Types for PostgreSQL\n";
-print "-- http://postgis.net\n";
-print "--\n";
-print "-- This is free software; you can redistribute and/or modify it under\n";
-print "-- the terms of the GNU General Public Licence. See the COPYING file.\n";
-print "--\n";
-print "--\n";
-print "-- Generated on: " . $time . "\n";
-print "--           by: " . $0 . "\n";
-print "--          for: " . $extname . "\n";
-print "--         from: " . ( @ARGV ? $ARGV[0] : '-' ) . "\n";
-print "--\n";
-print "-- Do not edit manually, your changes will be lost.\n";
-print "--\n";
-print "\n";
-print "-- complain if script is sourced in psql\n";
-print '\echo Use "CREATE EXTENSION ' . ${extname} .
-      '" to load this file. \quit';
-print "\n\n";
 print "-- Register all views.\n";
 foreach my $view (@views)
@@ -273,9 +287,8 @@ foreach my $cast (@casts)
-print "-- Register all functions except " . (keys %type_funcs) . " needed for type definition.\n";
-my @type_funcs= (); # function to drop _after_ type drop
-foreach my $fn (@funcs)
+print "-- Register all functions.\n";
+foreach my $fn ( @funcs )
 	if ($fn =~ /.* function ([^(]+)\((.*)\)/is ) # can be multiline
@@ -283,36 +296,11 @@ foreach my $fn (@funcs)
 		my $fn_arg = $2;
 		$fn_arg = strip_default($fn_arg);
-		if ( ! exists($type_funcs{$fn_nm}) )
-			add_if_not_exists("FUNCTION $fn_nm ($fn_arg)");
-		else
-			push(@type_funcs, $fn);
-	else
-		die "Couldn't parse FUNCTION line: $fn\n";
-print "-- Add all functions needed for types definition (needed?).\n";
-foreach my $fn (@type_funcs)
-	if ($fn =~ /.* function ([^(]+)\((.*)\)/i )
-		my $fn_nm = $1;
-		my $fn_arg = $2;
-		$fn_arg =~ s/DEFAULT [\w']+//ig;
 	else
-		die "Couldn't parse line: $fn\n";
+		die "Couldn't parse FUNCTION line: $fn\n";
@@ -336,6 +324,43 @@ foreach my $type (@types)
+print <<"EOF";
+DROP FUNCTION _postgis_package_object(text, text);
+-- Security checks
+DO LANGUAGE 'plpgsql' \$BODY\$
+DECLARE
+	rec RECORD;
+BEGIN
+	-- Check ownership of extension functions
+	-- matches ownership of extension itself
+	FOR rec IN
+		SELECT
+			p.oid,
+			p.proowner,
+			e.extowner
+		FROM pg_catalog.pg_depend AS d
+			INNER JOIN pg_catalog.pg_extension AS e ON (d.refobjid = e.oid)
+			INNER JOIN pg_catalog.pg_proc AS p ON (d.objid = p.oid)
+		WHERE d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass
+		AND deptype = 'e'
+		AND e.extname = '${extname}'
+		AND d.classid = 'pg_catalog.pg_proc'::pg_catalog.regclass
+		AND p.proowner != e.extowner
+	LOOP
+		RAISE EXCEPTION 'Function % is owned by % but extension is owned by %',
+				rec.oid::regprocedure, rec.proowner::regrole, rec.extowner::regrole;
+	END LOOP;
+	-- TODO: check ownership of more objects ?
+END;
+\$BODY\$;
+EOF
 print "\n";
 1;
Summary of changes:
 NEWS                       |   1 +
 utils/create_unpackaged.pl | 161 ++++++++++++++++++++++++++-------------------
 2 files changed, 94 insertions(+), 68 deletions(-)
hooks/post-receive
