[postgis-tickets] [PostGIS] #4648: Have extension packaging scripts (FROM unpackage) check objects ownership
PostGIS trac at osgeo.org
Thu Oct 27 17:29:07 PDT 2022
  Reporter:  strk                   |      Owner:  strk
      Type:  enhancement            |     Status:  closed
  Priority:  medium                 |  Milestone:
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:  pg13
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"6c1718af32c2abac17b6402eab383fe0832aac06/git"
 6c1718af/git]:
 {{{#!CommitTicketReference repository="git"
 revision="6c1718af32c2abac17b6402eab383fe0832aac06"
 Check ownership of functions match that of extension upon packaging
 References #4648 in 3.0 branch (3.0.8dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4648#comment:10>
