[postgis-tickets] [PostGIS] #5081: ERROR: ptarray_scroll_in_place: input POINTARRAY does not contain the given point
PostGIS trac at osgeo.org
Fri Oct 28 12:47:39 PDT 2022
given point
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.0
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by strk):
 I guess the reason why this doesn't happen often is because it is rare
 that the intersection between an incoming *closed* line and pre-existing
 lines is also closed, as that is only possible when the incoming line is
 non-simple (self-intersecting)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5081#comment:8>
