[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.7-12-gb768f1c9d
    git at osgeo.org
    git at osgeo.org
    Sat Oct 29 06:35:52 PDT 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  b768f1c9d014a0f82a2d776b57304f91c8c6d4f2 (commit)
       via  4af1190b7ce3ece4712c95dbf918e2879c79a2fd (commit)
       via  54071eeb620a9b6a0a5855f13aff1592e8e75c36 (commit)
      from  26a6a68139a0889cb822892774f96ed6fb001cad (commit)
revisions in full, below.
commit b768f1c9d014a0f82a2d776b57304f91c8c6d4f2
Merge: 4af1190b7 26a6a6813
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Oct 29 09:35:42 2022 -0400
    Merge branch 'stable-3.0' of git.osgeo.org:postgis/postgis into stable-3.0
commit 4af1190b7ce3ece4712c95dbf918e2879c79a2fd
Date:   Sat Oct 29 00:47:24 2022 -0400
    Berrie64  changes
    1. Error on first fail
    2. Do garden tests
    3. Use Geos 3.9 build run
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index e3ec00030..f1a1871d0 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
@@ -1,11 +1,14 @@
-#!/bin/bash
+#!/usr/bin/env bash
+set -e
 # Berrie64 is a 64-bit Rasberry Pi Arm managed by Bruce Rindahl
 ## BRANCH is passed in via jenkins which is set via gitea web hook
 #export BRANCH=618a67b1d6fc223dd5a4c0b02c824939f21dbd65
 ## label is set by jenkins
 #export label=${label}
+export GEOS_VER=3.9.4
 export WORKSPACE=/home/jenkins/workspace
+export GEOS_PATH=${WORKSPACE}/geos/rel-${GEOS_VER}
 cd ${WORKSPACE}/PostGIS_Worker_Run/label/${label}/$BRANCH
 export OS_BUILD=64
@@ -18,7 +21,7 @@ export PGDATA=$PGPATH/data_${PGPORT}
 export PGHOST=localhost
 sh autogen.sh
-./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-library-minor-version
+./configure --with-pgconfig=${PGPATH}/bin/pg_config --with-geosconfig=${GEOS_PATH}/bin/geos-config --with-library-minor-version
 #make clean
 make
 export err_status=0
@@ -26,6 +29,8 @@ make check RUNTESTFLAGS="-v"
 make install
 make check RUNTESTFLAGS="-v --extension"
 err_status=$?
+make garden
+err_status=$?
 if [ -d $PGDATA/postmaster.pid ] ; then
 	$PGCTL stop -D $PGDATA -s -m fast
commit 54071eeb620a9b6a0a5855f13aff1592e8e75c36
Date:   Thu Oct 27 19:18:56 2022 -0400
    Fix crash in ST_SnapToGrid on Empties
    References #5241 for PostGIS 3.0.8
diff --git a/NEWS b/NEWS
index f394d180c..563b072df 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ YYYY/MM/DD
   - Add schema qual to upgrade util
   - #5240, ST_DumpPoints crash with empty polygon (Regina Obe)
   - #4648, Check function ownership at extension packaging time (Sandro Santilli)
+  - #5241, Crash on ST_SnapToGrid with empty multis (Regina Obe)
 PostGIS 3.0.7
 2022/08/18
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index 8f9a5705b..a07ca53a1 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -2144,6 +2144,7 @@ void
 lwgeom_grid_in_place(LWGEOM *geom, const gridspec *grid)
 	if (!geom) return;
+	if (lwgeom_is_empty(geom)) return;
 	switch ( geom->type )
 		case POINTTYPE:
diff --git a/regress/core/snaptogrid.sql b/regress/core/snaptogrid.sql
index 0b6f5bd97..ae12da4d9 100644
--- a/regress/core/snaptogrid.sql
+++ b/regress/core/snaptogrid.sql
@@ -19,3 +19,7 @@ WITH geom AS
     SELECT ST_SnapToGrid('POLYGON((0 0, 10 0, 10 10, 10.6 10, 10.5 10.5, 10 10, 0 10, 0 0))', 'POINT(0 0)', 10, 10, 10, 10) as g
 Select ST_AsText(g) as geometry, postgis_getbbox(g) AS box from geom;
+-- #5241
+SELECT '#5241' AS t, ST_AsText(ST_SnapToGrid( ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2 4, 7 7, 9 9)), EMPTY)', 4326),  20.1, 20.1, 20.1, 20.1));
+SELECT '#5241' AS t, ST_AsText(ST_SnapToGrid( ST_GeomFromText('MULTIPOLYGON (((9 9, 9 1, 1 1, 2 4, 7 7, 9 9)), EMPTY)', 4326), 0.2, 0.2, 0.2, 0.2));
diff --git a/regress/core/snaptogrid_expected b/regress/core/snaptogrid_expected
index 518c1734b..2e8f2b4ab 100644
--- a/regress/core/snaptogrid_expected
+++ b/regress/core/snaptogrid_expected
@@ -5,3 +5,5 @@ t
 t
 POLYGON((0 0,10 0,10 10,0 10,0 0))|BOX(0 0,10 10)
+#5241|MULTIPOLYGON EMPTY
+#5241|MULTIPOLYGON(((9 9,9 1,1 1,2 4,7.000000000000001 7.000000000000001,9 9)))
Summary of changes:
 NEWS                             | 1 +
 ci/berrie64/postgis_regress.sh   | 9 +++++++--
 liblwgeom/lwgeom.c               | 1 +
 regress/core/snaptogrid.sql      | 4 ++++
 regress/core/snaptogrid_expected | 2 ++
 5 files changed, 15 insertions(+), 2 deletions(-)
hooks/post-receive
