[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-299-g20d228931
Sat Oct 29 07:22:33 PDT 2022
the project "PostGIS".
       via  20d228931b9b4a0a594669df27bdc25dbc30a146 (commit)
      from  6021ef4dfc496612cd0b9678cedcd8fc206c1f0b (commit)
revisions in full, below.
commit 20d228931b9b4a0a594669df27bdc25dbc30a146
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Oct 29 16:21:46 2022 +0200
    Encode dependency of unpackaged script on install script
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 7b425b060..1d5619bc4 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -56,16 +56,6 @@ EXTENSION_UPGRADE_SCRIPTS = \
 	sql/spatial_ref_sys_config_dump.sql \
 	../postgis_extension_helper_uninstall.sql
-# Scripts making up the extension upgrade-from-unpackaged file
-# NOTE: order matters
-# TODO: DROPME
-EXTENSION_UNPACKAGED_UPGRADE_SCRIPTS = \
-	../postgis_extension_helper.sql \
-	sql/raster_unpackage.sql \
-	sql/postgis_upgrade.sql \
-	../../doc/postgis_comments.sql \
-	../postgis_extension_helper_uninstall.sql
 RASTER_DROP_SCRIPTS = \
 	../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql \
 	../../raster/rt_pg/rtpostgis_drop.sql \
@@ -104,10 +94,10 @@ sql/$(EXTENSION)--$(EXTVERSION).sql: $(EXTENSION_SCRIPTS) | sql
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
-sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql/$(EXTENSION)--ANY--$(EXTVERSION).sql ../../utils/create_unpackaged.pl Makefile | sql
-	cat sql/$(EXTENSION)--$(EXTVERSION).sql | $(PERL) @top_srcdir@/utils/create_unpackaged.pl postgis > $@
+sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql ../../utils/create_unpackaged.pl Makefile | sql
+	$(PERL) @top_srcdir@/utils/create_unpackaged.pl postgis < sql/$(EXTENSION)--$(EXTVERSION).sql > $@
 	# Upgrade after packaging
-	cat $< >> $@
+	cat sql/$(EXTENSION)--ANY--$(EXTVERSION).sql >> $@
 sql/$(EXTENSION)--unpackaged.sql: Makefile | sql
Summary of changes:
 extensions/postgis/Makefile.in | 16 +++-------------
 1 file changed, 3 insertions(+), 13 deletions(-)
hooks/post-receive
