[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-32-g8d482e264
Sat Sep 3 10:40:47 PDT 2022
the project "PostGIS".
       via  8d482e264cec6ab3903653bd8db41ffc404ca758 (commit)
      from  243467d91058ce703f50de9e89803f81e93579e9 (commit)
revisions in full, below.
commit 8d482e264cec6ab3903653bd8db41ffc404ca758
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Sep 3 13:40:42 2022 -0400
    Fix debbie's make dist.  Needs to be > PG 11. References #5229 for PostGIS 3.4.0
diff --git a/ci/debbie/postgis_make_dist.sh b/ci/debbie/postgis_make_dist.sh
index 4ada3c6fe..a6078b988 100644
--- a/ci/debbie/postgis_make_dist.sh
+++ b/ci/debbie/postgis_make_dist.sh
@@ -2,15 +2,15 @@
 set -e
 ## begin variables passed in by jenkins
-export PG_VER=11
+export PG_VER=13
 # export PGPORT=8442
 export OS_BUILD=64
 # export POSTGIS_MAJOR_VERSION=2
 # export POSTGIS_MINOR_VERSION=2
 # export POSTGIS_MICRO_VERSION=0dev
 export PROJECTS=/var/lib/jenkins/workspace
-export GEOS_VER=3.9
-export GDAL_VER=3.0
+export GEOS_VER=3.10
+export GDAL_VER=3.4
 export WEB_DIR=/var/www/postgis_stuff
 export PATH="${PGPATH}/bin:$PATH"
 export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
Summary of changes:
 ci/debbie/postgis_make_dist.sh | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
