[postgis-tickets] [PostGIS] #5236: ERROR: type "raster" is only a shell
PostGIS trac at osgeo.org
Wed Sep 7 14:42:22 PDT 2022
  Reporter:  marc3932  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.2.4
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:  postgis_raster
Comment (by marc3932):
 PostgreSQL Documentation
 https://www.postgresql.org/docs/current/sql-createtype.html
 There are five forms of CREATE TYPE, as shown in the syntax synopsis
 above. They respectively create a composite type, an enum type, a range
 type, a base type, or a **shell type**. The first four of these are
 discussed in turn below. A **shell type** is simply a placeholder for a
 type to be defined later; it is created by issuing CREATE TYPE with no
 parameters except for the type name. **Shell types** are needed as forward
 references when creating range types and base types, as discussed in those
 sections.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5236#comment:1>
