[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-71-g811a53939
Fri Sep 9 05:50:26 PDT 2022
the project "PostGIS".
       via  811a5393964a3951ba432b4ba98096cffaca3684 (commit)
       via  55960a97c2977a34ba3a3c6b3da6aa3efa56ae97 (commit)
       via  63ac3938ff8235bb21a30a357d96969de0e15991 (commit)
      from  fef9548278c9936763629ff9756e8d6dab2a333a (commit)
revisions in full, below.
commit 811a5393964a3951ba432b4ba98096cffaca3684
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri Sep 9 07:49:40 2022 +0000
    Translated using Weblate (Japanese)
    Currently translated at 100.0% (112 of 112 strings)
    Translation: postgis/reference_lrs.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_lrsxml/ja/
diff --git a/doc/po/ja/reference_lrs.xml.po b/doc/po/ja/reference_lrs.xml.po
index 777a3fc74..9659471b4 100644
--- a/doc/po/ja/reference_lrs.xml.po
+++ b/doc/po/ja/reference_lrs.xml.po
@@ -7,7 +7,7 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-07-14 02:04+0000\n"
-"PO-Revision-Date: 2022-09-08 03:55+0000\n"
+"PO-Revision-Date: 2022-09-09 12:50+0000\n"
 "Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "reference_lrsxml/ja/>\n"
commit 55960a97c2977a34ba3a3c6b3da6aa3efa56ae97
Date:   Fri Sep 9 07:47:03 2022 +0000
    Currently translated at 100.0% (276 of 276 strings)
    Translation: postgis/reference_input.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_inputxml/ja/
diff --git a/doc/po/ja/reference_input.xml.po b/doc/po/ja/reference_input.xml.po
index 5784c1b27..233b12e5c 100644
--- a/doc/po/ja/reference_input.xml.po
+++ b/doc/po/ja/reference_input.xml.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "POT-Creation-Date: 2022-04-16 08:20+0000\n"
 "reference_inputxml/ja/>\n"
@@ -201,8 +201,9 @@ msgid ""
 "\"ST_BuildArea\">ST_BuildArea()</link> for a postgis-specific approach."
 msgstr ""
 "WKTがMULTILINESTRINGでない場合には、エラーが投げられます。出力が単一のポリゴ"
-"ンであってもマルチポリゴンに強制されます。単一のポリゴンが返って欲しい場合は"
-"ST_BdPolyFromTextを使うかPostGIS独特のアプローチとして<link linkend="
+"ンであってもマルチポリゴンに強制されます。"
+"単一のポリゴンが返って欲しい場合は<link linkend=\"ST_BdPolyFromText\""
+">ST_BdPolyFromText</link>を使うかPostGIS独特のアプローチとして<link linkend="
 "\"ST_BuildArea\">ST_BuildArea()</link>をご覧ください。"
 #. Tag: para
@@ -1765,10 +1766,10 @@ msgid ""
 "case, a <varname>LINESTRING</varname> geometry. This function plays the role "
 "of the Geometry Factory in SQL."
 msgstr ""
-"<varname>ST_LineFromWKB</varname>は、ジオメトリのWell-Known Binary表現と空間"
-"参照系識別番号 (SRID)を取り、適切なジオメトリタイプを返します。この場合は"
-"LINESTRINGジオメトリです。この関数はSQLのジオメトリファクトリの役割を果たしま"
-"す。"
+"<varname>ST_LineFromWKB</varname>は、ジオメトリのWell-Known "
+"Binary表現と空間参照系識別番号 (<varname>SRID</varname>)を取り、適切なジオメ"
+"トリタイプを返します。この場合は<varname>LINESTRING</varname>ジオメトリです。"
+"この関数はSQLのジオメトリファクトリの役割を果たします。"
 #. Tag: para
 #: reference_input.xml:901
@@ -1868,10 +1869,10 @@ msgid ""
 "geometry type - in this case, a <varname>LINESTRING</varname> geometry. This "
 "function plays the role of the Geometry Factory in SQL."
 msgstr ""
-"<varname>ST_LinestringFromWKB</varname>は、ジオメトリのWell-Known Binary表現"
-"と空間参照系識別番号 (<varname>SRID</varname>を取り、適切なジオメトリタイプの"
-"インスタンスを生成します。この場合、LINESTRINGジオメトリです。この関数はSQLの"
-"ジオメトリファクトリの役割を果たします。"
+"<varname>ST_LinestringFromWKB</varname>は、ジオメトリのWell-Known "
+"Binary表現と空間参照系識別番号 (<varname>SRID</varname>を取り、適切なジオメト"
+"リタイプのインスタンスを生成します。この場合、<varname>LINESTRING</varname>ジ"
+"オメトリです。この関数はSQLのジオメトリファクトリの役割を果たします。"
 #. Tag: para
 #: reference_input.xml:969
@@ -1974,7 +1975,8 @@ msgid ""
 "<varname>POINT</varname> geometry."
 msgstr ""
 "SRIDが指定されていない場合は0 (不明)となります。入力<varname>bytea</varname>"
-"がPOINTジオメトリを表現しないなら<varname>NULL</varname>が返されます。"
+"が<varname>POINT</varname>ジオメトリを表現しないなら<varname>NULL</varname>が"
+"返されます。"
 #. Tag: para
 #: reference_input.xml:1036
commit 63ac3938ff8235bb21a30a357d96969de0e15991
Date:   Fri Sep 9 07:25:32 2022 +0000
    Currently translated at 100.0% (68 of 68 strings)
    Translation: postgis/reference_guc.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_gucxml/ja/
diff --git a/doc/po/ja/reference_guc.xml.po b/doc/po/ja/reference_guc.xml.po
index 3acc025cc..c90c51a69 100644
--- a/doc/po/ja/reference_guc.xml.po
+++ b/doc/po/ja/reference_guc.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "POT-Creation-Date: 2021-09-11 01:55+0000\n"
 "reference_gucxml/ja/>\n"
@@ -297,9 +297,9 @@ msgid ""
 "<varname>DISABLE_ALL</varname> overrides all other values in "
 "<varname>postgis.gdal_enabled_drivers</varname>."
 msgstr ""
-"<varname>DISABLE_ALL</varname> 全てのGDALドライバを無効にします。これが出現す"
-"ると、 <varname>postgis.gdal_enabled_drivers</varname>にある他の全ての値を上"
-"書きします。"
+"<varname>DISABLE_ALL</varname> 全てのGDALドライバを無効にします。<varname>DIS"
+"ABLE_ALL</varname>は<varname>postgis."
+"gdal_enabled_drivers</varname>にある他の全ての値を上書きします。"
 #. Tag: para
 #: reference_guc.xml:118
@@ -355,7 +355,7 @@ msgstr ""
 #: reference_guc.xml:148
 #, no-c-format
 msgid "Set and reset <varname>postgis.gdal_enabled_drivers</varname>"
-msgstr " <varname>postgis.gdal_enabled_drivers</varname>の設定とリセット。"
+msgstr "<varname>postgis.gdal_enabled_drivers</varname>の設定とリセット。"
 #. Tag: para
 #: reference_guc.xml:150
Summary of changes:
 doc/po/ja/reference_guc.xml.po   | 10 +++++-----
 doc/po/ja/reference_input.xml.po | 26 ++++++++++++++------------
 doc/po/ja/reference_lrs.xml.po   |  2 +-
 3 files changed, 20 insertions(+), 18 deletions(-)
hooks/post-receive
