[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.3-6-g0abd582c6
Fri Sep 9 23:17:08 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  0abd582c66b8622412a013d95f159a8423b03d45 (commit)
      from  9921d5ce2a92966605341823807dbfe1d7487f38 (commit)
revisions in full, below.
commit 0abd582c66b8622412a013d95f159a8423b03d45
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Sep 10 02:16:57 2022 -0400
    Prep for PostGIS 3.2.4 release
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 87b5126c3..bc7b42595 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,6 +1,6 @@
 How to release
-Date: 2022-07-22
+Date: 2022-09-10
 Versioning Scheme
@@ -64,7 +64,7 @@ Release procedure
   - Can edit tickets and milestones on https://trac.osgeo.org/postgis/
   - Can commit to upstream git https://git.osgeo.org/gitea/postgis/postgis
-  - Have SSH to download.osgeo.org and can write to /osgeo/download/postgis.
+  - Have SSH to upload.osgeo.org and can write to /osgeo/download/postgis.
   - Have SSH to postgis.net and can write to /etc/nginx/sites-enabled/postgis.net.
   - Post to https://git.osgeo.org/gitea/postgis/postgis.net/ and get it added to feed
   https://planet.postgresql.org/register/new/
@@ -94,7 +94,7 @@ Release procedure
   - Commit all changes
   - If this is a minor or major release (no branch exists):
 	   $ rev=x.x
-	   $ git checkout master; git checkout -b "$rev"; git push -u osgeo $rev
+	   $ git checkout master; git checkout -b "stable-$rev"; git push -u osgeo $rev
 	   Go to: https://debbie.postgis.net and copy last branch version and make new job
 	   a) Replace PostGIS_* string params with new version
@@ -123,7 +123,7 @@ Release procedure
   - PostGIS doc release versioned doc - http://postgis.net/documentation/
     - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
-         - nginx -t #to confirm you didn't breat the config
+         - nginx -t #to confirm you didn't break the config
          - service nginx reload
       Verify the documentation is up to date (might need to change the nginx config)
diff --git a/NEWS b/NEWS
index 716780cb6..3a0d5a01d 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.2.4dev
-2022/MM/DD
+PostGIS 3.2.4
+2022/09/10
 * Bug Fixes *
   - #5227, typo in ST_LineLocatePoint error message (Sandro Santilli)
diff --git a/Version.config b/Version.config
index c89152f40..bc0d15b69 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=4dev
+POSTGIS_MICRO_VERSION=4
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 9ece503b2..b7bfa1851 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,29 @@
 <appendix id="release_notes">
   <title>Appendix</title>
    <subtitle>Release Notes</subtitle>
+    <sect1>
+        <title>PostGIS 3.2.4</title>
+        <para>2022/09/09</para>
+            <para>This version requires PostgreSQL 9.6-15, GEOS 3.6 or higher, and Proj 4.9+
+            Additional features are enabled if you are running GEOS 3.9+
+            (and ST_MakeValid enhancements with 3.10+),
+            Proj 6.1+, and PostgreSQL 14+.</para>
+        <simplesect>
+            <title>Bug Fixes</title>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5227">5227</ulink>, typo in ST_LineLocatePoint error message (Sandro Santilli)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5231">5231</ulink>, PG15 no longer compiles because SQL/JSON removed PG upstream (Regina Obe)</para>
+        </simplesect>
+    </sect1>
+    <sect1>
+        <title>PostGIS 3.2.3</title>
+        <para>2022/08/18</para>
+    </sect>
    <sect1>
         <title>PostGIS 3.2.2</title>
         <para>2022/07/22</para>
Summary of changes:
 HOWTO_RELEASE         |  8 ++++----
 NEWS                  |  4 ++--
 Version.config        |  2 +-
 doc/release_notes.xml | 23 +++++++++++++++++++++++
 4 files changed, 30 insertions(+), 7 deletions(-)
hooks/post-receive
